Old 08-19-2006, 08:30 PM   #1
Best way to remove "stucco" finish for ceiling
I am tryng to remove joint compound stucco finish from kitchen drywall ceiling and I'm gouging it badly. What is the best method for doing this? Thanks.
HomeRepairNoob is offline   Reply With Quote
Old 08-19-2006, 10:26 PM   #2
mist it with water
redline is offline   Reply With Quote
Old 08-20-2006, 02:01 AM   #3
747
registered
747's Avatar
yep get a pump sprayer fill with water spray (saturate) the ceiling and scrap if it doesn't scrap off smooth you need more water.
747 is offline   Reply With Quote
Old 09-03-2006, 07:57 PM   #4
The Flying Toolbox
handypilot's Avatar
This is a real good ARTICLE on how to handle it, especially if the popcorn texture contains asbestos.
handypilot is offline   Reply With Quote
Old 01-24-2007, 09:49 PM   #5
Will this work on stucco that has been painted? I cannot confirm if it was painted with latex or oil.
MicDIY is offline   Reply With Quote
Old 01-24-2007, 10:46 PM   #6
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Try it and see - not much to loose
Brik is offline   Reply With Quote
Old 07-03-2008, 08:19 PM   #7
My wife and I just went thru that. The living was painted with oil based, which the water won't penetrate, so we scraped off as much of the thicker stuff as we could with a 6" mudding knife and re drywalled. Don't use 1/4" drywall...It'll show the ridges. Go with the half inch. To find out if it's painted with latex or oil, spray an area of about 2 feet by 2 feet...If it's latex, it will get darker right away, and start to bubble. 10 minutes later, you can scrape it right off. If it's oil, the water will bead right on the surface. Hope this helps
jmaurente is offline   Reply With Quote
Old 07-03-2008, 09:47 PM   #8
Tired, Cold, and Damp
slickshift's Avatar
Wet and scrape
Messy but effective
slickshift is offline   Reply With Quote
remove steam radiator rick2665 HVAC 11 03-09-2010 08:29 PM
cabinet maker's finish jim_k Painting 5 08-03-2007 02:37 PM
remove damage vinyl tiles harold938 Carpentry 2 11-16-2006 01:14 AM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 05:12 PM
