Best Way To Remove Dried Paint From A Wall - Painting - DIY Chatroom Home Improvement Forum
Old 10-02-2013, 11:37 PM   #1
Rewards Points: 40
Best way to remove dried paint from a wall
I cleaned the kitchen walls before painting, but apparently not well enough. Ended up with a primer coat sagging on the wall, with some kind of oily surface causing the problem. My partner suggested to allow the primer to dry and scrape it off the next day. This dried primer is like rock (called Bulls Eye 1-2-3). Any suggestions on the best way to remove it would be appreciated. Area is about 4 ft. wide by 8 ft. high. Thanks!
teejersey is offline   Reply With Quote
Old 10-03-2013, 04:56 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
If it is adhered well, why remove it? If you really need to get it off, let it dry a couple weeks and sand it off.
chrisn is online now   Reply With Quote
Old 10-03-2013, 07:32 AM   #3
Gymschu's Avatar
Rewards Points: 230
What Chris said. No need to remove it. Sand off the runs and spot prime those areas and you're back in business. Can't imagine primer being rock hard after a day or so but that would be to your advantage when sanding. Soft, gooey stuff in much harder to sand. Buy a 3m Sanding sponge or some 150 grit sandpaper and see how that works. If it doesn't remove the runs, scrape as much off as you can with a razor blade scraper then sand with an electric palm sander. It will take some elbow grease but it can be done.
Gymschu is online now   Reply With Quote
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 06:19 PM
remove oil and latex paint from wall Ana Carolina Painting 2 12-02-2010 07:33 PM
Remove dried paint from wood baseboards dunavantc Painting 2 07-16-2009 03:54 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
