Best Way To Prep And Paint Stained Trim White - Painting - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 01:47 PM   #1
Best way to prep and paint stained trim white
I am about to paint my stained wood trim white. I want to make sure to get it right the first time.
What prep work do I need to do? Sand? Oil or Latex Primer? Do I need to sand again after priming? Can I use Latex paint over oil primer or is Oil paint what I need.
TIA
ShelleyJ is offline   Reply With Quote
Old 03-10-2012, 01:50 PM   #2
bubbler's Avatar
Rewards Points: 256
TIA
I sanded flat areas and used a liquid deglosser on more intricate parts.
There are latex primers that claim to adhere to gloss, they are Ok, but not great in my experience. I used Zissner Cover Stain, but there is also a product called BIN that seems to be good. Both claim you don't need to sand or degloss first. Once you have it primed you can use standard latex over it I believe.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Old 03-10-2012, 05:26 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 136
TIA
Lightly sand, clean dust, prime( oil or latex,Stain Blocking Primer) I would use Fresh Start or Pro Block, LIGHTLY sand . clean, paint (oil or latex)
Old 03-15-2012, 08:59 AM   #4
I primed the trim using the Color Stain and it looks awful. There are brush marks and the coverage is slim. I used a Purdy XL brush. I wonder what I did wrong.
Old 03-15-2012, 10:16 AM   #5
Too Short? Cut it Again!
Zinsser Cover Stain should do the trick for a primer. As Chris mentioned, Fresh Start (Benjamin Moore) or Pro Block (Sherwin Williams) would be other good choices. The primer will not cover completely and it is normal to see some show through. Just be sure, brush out a bit of your finish and see if things do not look better?
If there is something on the trim that actually bleeds up through the primer and paint, you will have to shift to a shellac based sealer/primer like Zinsser BIN. It is an alcohol solvent product so you need plenty of ventilation.
Old 03-15-2012, 10:19 AM   #6
bubbler's Avatar
Rewards Points: 256
You mean you used "Cover Stain" right? It's the stain hiding primer... it will not give you a good white color and look perfect, you put that on... then you can lightly sand after it's very dry. Then you put a nice glossy white trim paint over that.
I had to do 2 coats of Cover Stain and then 2 coats of trim paint to handle my dark stained trim wood work.
Old 03-15-2012, 02:41 PM   #7
chrisn's Avatar
Rewards Points: 136
No you did not HAVE too, 1 coat of primer is all you ever need, 2 coats is a waste or time and $$
Old 03-15-2012, 02:59 PM   #8
Yes, I meant Cover Stain. Sorry about that.
Also, what grit of sand paper do I need to sand the primer with?
Old 03-15-2012, 03:51 PM   #9
bubbler's Avatar
Rewards Points: 256
You're right...
For explanations sake--The reason I used 2 coats in certain areas (bathroom & kitchen windows) is that I found there were brush marks that were deep enough to expose very thin (think brush strand sized) darker streaks. I didn't want to risk there being darker areas.
Another area I used Cover Stain was where we removed a wall between our kitchen and dining room, in that corner there had been a corner built-in. We had layers of paint leading up to the built-in, as well as HEAVY nicotine stains where the built in touched the wall. I did two coats of the Cover Stain over that are because I was looking to build it up a bit, and also make sure that the two areas were both the same color... I didn't want any shadow/outlining.
So in my case the 2nd coat was really insurance and also issues caused by my poor application. I chose the "Cover Stain" which is oil based because we had some poor performance from latex based stain covering primers (mostly with them not blocking smell and leaching colors through). I only bought a quart sized container and it hardly looks like I've even used 10-15% of it.
For the general trim around the rest of the windows/doors/floors in the house we used Sherwin William's latest based "Adhesion Primer". It goes on and looks terrible, a mess of streaks and darker/lighter areas... but once you get the trim paint over it, it looks good. Here is was a case of not wanting to deal with the effects of the oil paint over a large amount of work, the latex is simply easier.
Old 03-15-2012, 05:02 PM   #10
Bubbler, How is your trim holding up using the latex SW Primer? Was the trim stained before you painted it white?
Old 03-15-2012, 10:48 PM   #11
bubbler's Avatar
Rewards Points: 256
It's holding up well enough--though the oldest work is only a couple of months old.
Our trim was stained very dark brown, almost black... so I was worried about how it would turn out, but it looks quite nice, with no bleed through.
My girlfriend was in charge of the areas where the latex primer was used, and I know she had become an expert at prep, so she probably did a better job on the two or three areas I did... she would spend about two to three hours per window/door between sanding, filling holes/gaps/etc, priming and then painting. I think I spent about an hour total on the two windows I did.
Old 06-23-2012, 10:32 AM   #12
questions on cover stain..
ok so ive been doing to research on this zinsser cover stain primer..or trying to! so many mixed reviews tho...i am looking for the quickest and easiest process to paint my trim throughout the living room white..without having to sand it all down! we have a 3 yr old and a 1 yr old so our hands r full as it is but its the only room without white trim and it is driving me crazy!! want to try this but i am scared to death that it is going to create a huge mess for me and i do not want to have to go back and sand it all down and what not..am i safe to buy this cover stain primer then just go over it with white paint without sanding at all??!!
askjrak91810 is offline   Reply With Quote
Techniques and tips EvilNCarnate Painting 5 01-11-2012 07:53 PM
Chipping latex paint on masonite prep question Brettjones Painting 1 10-17-2011 06:26 PM
What kind of paint for exterior trim? fabian Painting 4 08-11-2011 10:01 PM
Oak furniture, want to paint it white Truffell Painting 13 03-11-2011 09:03 AM
Questions about paint prep for exterior cedar siding. 240sx4u Painting 4 09-22-2008 11:46 PM
