Best Way To Finish Ruff Barn-board For Indoor Table? - Painting - DIY Chatroom Home Improvement Forum
Old 05-20-2008, 10:39 AM   #1
Best way to finish ruff barn-board for indoor table?
I've got some gorgeous old yellow pine planks that I pulled off the ceiling of my Dad's 80 year old shed. (They're tearing it down.) I want to build a table top for indoor use out of them. I've scrubbed them with a stiff brush and water and there is a lot of raised grain and texture to them which I'm leaving in place, no sanding.
My question is, what's the best way to finish these boards for use as a kitchen table? I figure the ultimate solution would be twenty coats of poly, but I live in a Manhattan apartment so I'm not sure I have the time and/or facility for that. I'm looking at some of these epoxy type coatings, like Famowood and Envirotex but I'm not sure exactly how I might apply these so they don't run off the edges and leave major drips.
BradG is offline   Reply With Quote
Old 05-20-2008, 02:22 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
At least with the envirotex (with which I am familiar), you would tape off the edges so it won't run over and drip
slickshift is offline   Reply With Quote
Old 05-20-2008, 02:26 PM   #3
slickshift's Avatar
...nice boards btw
I'm re-finishing an old coffee table top that was hand carved to look like an old wooden ship's deck door
As it's been through quite a bit itself now, it almost looks like it's that old
I sanded about 1/2-3/4 of the stain off and bleached it a bit
I'm not sure you could make a new piece of wood look like it for any amount of money
I plan on using marine varnish, but mines a bit smoother than yours
Good Luck!
Old 05-20-2008, 11:21 PM   #4
So, tape the edges with tape sticking up to form a sort of wall? Is that the technique? Then what, hit the edges with a light coat by brush?
What about cracks between the boards? Is there a sort of maximum width of crack that the Envirotex would be too thick to drip through?
Thanks.
Old 07-28-2008, 11:26 PM   #5
finishinng ruff boards
i work with barnboards in my furniture mfg business....sand them down with 40 or 60 grit...then to 100 grit....coat the with ZAR Poly (yu can use antique flat or satin) i use antique flat....then sand with 220 to 320 grit and coat again.
then sand with 320-400 grit and coat again.....viola...a beautiful finish.
van
van_purdy@hotmail.com is offline   Reply With Quote
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 10:58 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
