Best Way To Clean Up Metal Cap With Build Up Dirt? - Painting - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 08:54 PM   #1
Rewards Points: 107
Best way to clean up metal cap with build up dirt?
We have a lot of metal cap around the house because we have flat roof.
It is very dirty and some area, paint are chipping and coming off.
What is best way to clean this area without power washing?
Because location and type of roofing, we can't have too much water or water hose to clean the area.
But metal caps are quite dirty and need of new fresh coat of paint.
Can you recommend best cleansing solution to clean up using a sponge and be prepared for painting?
Andee77 is offline   Reply With Quote
Old 07-27-2012, 10:19 PM   #2
Too Short? Cut it Again!
Dirtex. I also like Purple Power from the auto store or Simple Green. Whatever you use, be sure and rinse it thoroughly.
If the caps are oxidized you should neutralize or remove the rust then prime with a metal primer before painting. A self etching metal primer from the auto store would be my choice.
Metal cap needs mildew clean up and caulking Andee77 Roofing/Siding 7 07-28-2012 06:07 PM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 07:34 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 05:02 PM
