Best Way To Clean Texture And Paint Overspray Off Garage Floor? - Painting - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 05:56 PM   #1
Best way to clean texture and paint overspray off garage floor?
I just had my garage drywalled, textured, and painted. Of course there is a mess. I have some texture and paint overspray on the floor. What's the best way to clean this stuff up without smearing it everywhere? Thanks for any ideas.
Mike
737Pilot is offline   Reply With Quote
Old 03-06-2009, 06:28 PM   #2
Whatamess
If it is dry scrap it then scrub with water and steel wool if needed.Hope it is a smooth floor. The joint compound will loosen with water. Paint not as easy.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 03-07-2009, 06:09 AM   #3
www.marylandpainter.net
bikerboy's Avatar
He is right about the joint compound. Just water for that.
If it is water based paint, you can purchase removers like "goo be gone", "krud cutter" and one more whose name I can't remember because there is not enough coffee in me yet.
Also de-natured alcohol will work on latex paint.
You may need a stiff wire brush to get into the pores.
bikerboy is offline   Reply With Quote
Old 03-09-2009, 02:47 AM   #4
Rewards Points: 1,016
similar problem -
I forwarned my dry-wallers, but still they failed to cover my garage concrete floor and trashed it, they used a pressure washer to make it right.
I have used a pressure washer myself to remove paint from a concrete patio after trying lots of other ways. The pressure washer worked and easily.
Old 03-09-2009, 05:56 PM   #5
Thanks guys...I'll try the pressure washer route with some goo gone or something!
Old 03-09-2009, 11:30 PM   #6
The pressure washer will probably readily remove everything without chemical assistance. In fact, with a high pressure unit and small tip you have to be careful not to cut into the concrete - or your foot.
Sand Texture in a Spray Can versus Textured Paint jweiner Remodeling 1 01-27-2009 04:29 PM
How long should I wait to paint texture? bluefitness Painting 1 12-11-2008 11:51 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 03:10 PM
painting my garage floor (and some outdoor slabs) - are these any good? joeyboy Flooring 2 10-17-2007 08:13 PM
