Best Way To Apply Drylok? - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 09:20 AM   #1
Rewards Points: 264
Best way to apply Drylok?
I searched and read a lot of posts on Drylok, none about application. We tried to get started this weekend on the unfinished poured walls of my 72'x24' basement. Knew a sprayer wouldn't work, couldn't get the power roller to take it either. We ended up slapping it on with an 3" brush and then finishing it with a 3/4" hand roller. In two days we are through 5 gallons, not half done.
THere has to be a better way... input?
moneymgmt is offline   Reply With Quote
Old 01-17-2012, 02:14 PM   #2
Too Short? Cut it Again!
I used to have a humongous brush for such things. I have also used a much thicker nap roller like 1" or even 1.5 inch which worked reasonably well. Either option is going to give your wrists and forearms a workout. Hope you have adequate ventilation! That stuff will get to you faster than you realize in a closed space.
Old 01-17-2012, 05:24 PM   #3
Unfortunately Money, you have to brush the first coat on. It has to be worked into the pores, not laid on top like a roller would apply. The second coat can be rolled. Why don't you pay someone to do it? From UGL website:
APPLICATION
STIR THOROUGHLY BEFORE
AND DURING APPLICATION. DO
NOT THIN. Paint only when air and surface temperatures are 50F or higher. Apply Latex Base DRYLOK
Masonry Waterproofer directly on
bare masonry. For best waterproofing results, wait for a dry (rain-free) period before application. Apply first coat with DRYLOK BRUSH or good quality nylon bristle brush working the WATERPROOFER into the pores of the masonry - avoid excessive brushing (see COVERAGE). APPLY
TWO COATS. Allow to dry 3 hours between coats. The second coat may be applied by brush, roller or spray.
For information on spray application, write UGL and ask for Spray
Specification Sheet D-88.
Old 01-17-2012, 05:28 PM   #4
Rewards Points: 13,712
I use a wide brush made for coating a roof. That way I can add a handle.
Old 01-17-2012, 09:43 PM   #5
Green Hat
Rewards Points: 170
APPLICATION
Thats about the way I did it. Used a mason paint brush on the 1st coat and rolled the 2nd coat with the thickest nap roller I could find. Worked out great for me........
Except for the fumes that ended up coming in my respirator, making me damn sick.........and reliving dreams from my college days.........
Mills314 is offline   Reply With Quote
Old 01-18-2012, 05:46 AM   #6
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I use Wooster Polar Bear roller covers to lay it on and then backbrush the first coat with at least a 4 inch brush to work it in. The Polar Bear alone does well on the second coat with minimal brushing.
Darkling Designs
poppameth is offline   Reply With Quote
Old 01-18-2012, 08:46 AM   #7
Rewards Points: 264
Thanks all. Guess I'll look for a bigger brush!
Old 01-18-2012, 08:57 AM   #8
Ironlight's Avatar
The stiffer the brush the better, within reason. They recommend bristle but nylon works fine and if you do the work over a period of time is much easier to repeatedly clean.
I have waterproofed three large basements with Dryloc over years so I know it well. Yes you will develop thick wrists. Yes it is a bear. And yes doing it right takes time because it's one of those jobs where proper preparation is both crucial and time consuming. Sounds like you have a recently built basement so that part is probably pretty straightforward.
I have found the way to make it manageable is to just chalk off sections of the wall...say 6' wide, and do them over a period of time, like one section every evening. Get a paddle mixer for your drill to mix it in the bucket, and a stiff nylon brush which is easy to clean. It's much less mind and wrist numbing of you only have to do 30 minutes of it a day.
Ironlight is offline   Reply With Quote
Old 01-18-2012, 09:24 AM   #9
Rewards Points: 264
Where can I find the brushes you guys are talking about? The Depot doesn't seem to have anything in line with that, at least not in the paint dept.
Old 01-18-2012, 10:21 AM   #10
Gymschu's Avatar
Rewards Points: 838
Most local "mom & pop" hardware stores carry the brushes as well as concrete mixing companies.......my local hardware store has them as well as my local sand & gravel plant......
Gymschu is online now   Reply With Quote
Old 01-18-2012, 09:16 PM   #11
Green Hat
Rewards Points: 170
I saw some at PPG Porter Paints as well.
Old 01-19-2012, 10:07 AM   #12
A well stocked paint store should have large brushes at fat roller covers.
Painting dry basement walls: Drylok or latex? Ironlight Painting 9 04-16-2011 09:37 PM
Why apply texture to drywall? acschnabel Drywall & Plaster 20 03-27-2011 05:42 PM
Painting basement floor, Drylok vs other? D270 Flooring 0 03-27-2011 04:57 PM
To Drylok or not to Drylok 68tele Painting 4 11-02-2009 07:40 AM
Drywall Taping - do you apply a layer of mud over the tape on your first go? newbpainter Drywall & Plaster 20 05-18-2009 06:43 AM
