Best Top-coat Over Oil Based Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 09:25 AM   #1
Best top-coat over oil based paint?
Hello - My husband and I are rehabbing an old barn. We've added a loft. I have painted the plywood floors with red oil-based paint. I am looking to put a coat (or two) of something on top, so the paint will not wear as quickly. Would a polyurethane work? Or an acrylic lacquer? Or something else? And why?
Jannie S is offline   Reply With Quote
Old 05-15-2011, 10:32 AM   #2
I would put a floor grade clear finish, just be sure that whatever you choose will be okay over oil. Depending on how long it's been since the floors were painted, you might have bonding issues with clear. Since you can't sand the floor to create a bond, you'll probably have to find a 100% acrylic finish with a strong bonding property. Go to a real paint store and explain what you have and need. Or, do some online reasearch for the best finish for your situation.
Old 05-16-2011, 11:53 AM   #3
Thanks, Joe. You were correct. I did go to a real paint store and got the same advice you offered. I purchased an Acrylic Clear Glaze. It is usually used as a top-coat after putting an epoxy coat on garage floors. But is appropriate for what I need also. Thanks for the great info!
acrylic lacquer , oil-based paint , polyurethane top coat
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Bathroom Pre-Painting Troubles LisaDarln Painting 6 10-22-2008 09:28 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
