Best Primer For Raw Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 06-25-2014, 01:18 PM   #1
Angry
best primer for raw drywall
I've done lots of work on my house, including new drywall. The texture is a smooth finish. After sanding, I've vacuumed the walls, sponged them, then dusted with a dust mop. No dust is visible on my finger when I check it. But no matter how fancy a PVA primer I buy, the finish coat bond is weak. Very low adhesive tape will always strip the paint AND primer right down to the unpainted drywall. Even with letting the PVA cure for a couple days. What am I doing wrong??? Should I stop using PVA primer?
Thanks in advance.
limechuck is offline   Reply With Quote
Old 06-25-2014, 01:20 PM   #2
^^I should say the PVA primer bond is weak. THe finish coat bonds to the primer fine. The PVA just does not seem to bond with the unpainted drywall...
Old 06-25-2014, 01:43 PM   #3
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
I use BINS or Kilz, I've never had a problem with it even with some dust.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 06-25-2014, 03:07 PM   #4
Gymschu's Avatar
Rewards Points: 490
PVA is just okay. If you're seeking a high quality primer, go to Sherwin-Williams or Benjamin Moore and get a quality drywall primer:
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
ltd (06-25-2014), ToolSeeker (06-25-2014)
Old 06-25-2014, 03:22 PM   #5
Rewards Points: 5,974
I agree with Shu. I would not use Bin for an entire room, just spot priming the smell for an entire room would be over whelming. The only Kilz I ever liked was the original and that was oil based so your back to the odor thing. I have not used the other Kilz products for quite a while though so they could have improved.
You don't say what PVA primer you are using, but something is wrong if it won't stick to the drywall. I would try as Shu recommended or at the least Zinzer 123.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (06-25-2014)
Old 06-25-2014, 03:58 PM   #6
mnp13's Avatar
Rewards Points: 512
Kilz stinks to high heaven, especially the shellac stuff, but it seals in everything and makes a perfect base for good primer. All of the paint we use is Benjamen Moore. We have almost no drywall in the current house, but I gutted all but two rooms in my last house and we primed with Kilz, then one coat of BM primer, then BM paint. The final paint finish was flawless.
Michelle
Old 06-25-2014, 04:04 PM   #7
The 2 I have in mind that I've used have been a high-end PVA primer from a Benjamin Moore retailer (not sure brand) and a low end Ace product. That probably doesn't help, but that's all I've got. Is there a difference between drywall primer and a PVA primer?
Old 06-25-2014, 05:34 PM   #8
Gymschu's Avatar
Rewards Points: 490
I've been in the painting biz for 35 years and have never had the problem you describe especially after you did such great prep and got rid of the dust. I've used PVA and good acrylic latex drywall primers and ALL have bonded to the drywall even some that was still a bit dusty.
There's an outside chance your drywall is defective. There have been several recalls in recent years especially with drywall made in China and sold at Lowe's stores.
Old 06-25-2014, 05:51 PM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
WHY Kilz IS a primer, you certainly did not need to add another primer on top of it
Old 06-25-2014, 06:03 PM   #10
mnp13's Avatar
Rewards Points: 512
No idea why I did it that way. It was 12 years ago. I remember it because of the unreal stench of the stuff. I used a power roller and did walls and ceilings of four rooms in a day (about 900 square feet) that was aweful... lol
Michelle
The Following User Says Thank You to mnp13 For This Useful Post:
chrisn (06-26-2014)
Old 06-25-2014, 08:29 PM   #11
Matthewt1970's Avatar
Rewards Points: 1,098
Sherwin Williams drywall primer is just fine. I have never been a fan of straight PVA primers. I hate to say it is a wasted step but every time I have used it is just seems like it really didn't seal the surface all that well and didn't leave much of any color, not that you are really looking for that much with a primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-26-2014, 06:58 AM   #12
Also, doesn't happen all the time, but flashing can be a problem with the PVA primer. I don't use it anymore now about all I use is the 123 and some times the SW.
Old 06-26-2014, 01:38 PM   #13
I've always been skeptical about PVA primers. Sounds like I need to spend a little more money on a better product. Thanks for the info everyone!!!
Tags
bonding , new drywall , paint , primer , pva
drywall mud problem - primer 1st or add mud dfphoto Drywall & Plaster 11 07-11-2014 01:26 PM
Drywall primer for new construction Tom2726 Painting 12 06-25-2014 03:12 PM
Which Primer? Clear Pine and Drywall HandyFrank Painting 7 01-27-2014 12:38 AM
Drywall Primer - What kind?I troyce1 Painting 6 01-25-2013 05:40 PM
Best Primer for New Drywall? aigsrone Painting 21 06-29-2012 08:31 PM
