Best Primer For Plaster Skim Coat Walls - HELP Please - Painting - DIY Chatroom Home Improvement Forum
Old 01-05-2017, 08:22 AM   #1
Rewards Points: 12
Best Primer for plaster skim coat walls - HELP please
Hello, 2 weeks ago we finished the plaster job. Now it is time to paint. I do not want to go through a tedious process of "misting" the walls, I would like to use a super primer. I did not find any new post on this topic and the technology has been improved in the last 6 years. Any suggestion? It is plaster on blue boards (not drywall compound). Thanks
kitui4u is offline   Reply With Quote
Old 01-05-2017, 08:47 AM   #2
Rewards Points: 40
Re: Best Primer for plaster skim coat walls - HELP please
Is it USG Diamond Veneer Plaster System? If so follow their technical bulletin. The worst thing you can do is take a shortcut at this point and use the wrong product because it's quicker or cheaper.
https://www.usg.com/content/dam/USG_...ng-en-PM15.pdf
abrowning is online now   Reply With Quote
Old 01-05-2017, 01:31 PM   #3
diypaintguy.com
DIYpaintGuy's Avatar
Rewards Points: 12
I have used Loxon Concrete & Masonry Primer from Sherwin Williams before without any problems. It works well with the high ph and will seal it up for the finish coat.
DIYpaintGUY
DIYpaintGuy is offline   Reply With Quote
Tags
paint , plaster , primer
Base color coat sticking better then primer? konsole Painting 8 08-22-2012 06:12 AM
NEW DRYWALL, new addition, Need Primer chipraynor Painting 50 11-09-2011 11:45 PM
Skim Coat bigfixer Painting 8 02-23-2010 11:42 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
