Best Primer And Paint For New Bathroom? - Painting - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 05:35 PM   #1
Best Primer and Paint for new bathroom?
I know this has probably been asked before, but I really want a definate answer.
I just gutted my bathroom and put up new drywall, and just got it taped and mudded.
I got a few questions...
1) What is the best way to clean off the dust before priming?
2) what is the best primer to use on the newly taped and mudded drywall?
3) What is the best paint to use in a bathroom?
Thanks!
Vikeologist is offline   Reply With Quote
Old 02-06-2010, 07:07 AM   #2
Best Primer and Paint for Bathrooms?
I posted this in the painting forum first, but no one has replied.
Thanks!
Last edited by Scuba_Dave; 02-06-2010 at 09:14 AM. Reason: 2 threads on same issue merged
Old 02-06-2010, 07:23 AM   #3
ccarlisle's Avatar
Much as I am loathe to answer "what's-the-best..." -type of questions, I can quickly offer this:
(1) HEPA vac
(2) Benjamin Moore's "Fresh Start" latex acrylic primer
(3) Zinsser's PermaWhite Bathroom paint
That, I find, to be the "best" in my book but I'll bet my 'best' doesn't correspond to your 'best'. Never can and never will.
But if you go by shear numbers of people who use this combo on a regular basis, and/or do this professionally, for pay, to satisfy not only oneself but others, then it may be a starting point with validation, for a newbie.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-06-2010, 07:25 AM   #4
the Zinsser Perma White says it has a 2 coat no prime. So I should still use a primer with this?
Old 02-06-2010, 07:46 AM   #5
ccarlisle's Avatar
Well, on new drywall, it may be a toss-up between a primer + Zinsser or two coats of zinsser. I don't usually ask my paint to do more that one job at a time, so if it were me, I'd prime it with a good primer then apply Zinssers bathroom paint. One or two coats would depend on the final colour chosen and the level of excellence in coverage I could live with.
But I would also make sure other bases are covered in a bathroom, like excess humidity control for one. Good fans...no, a really good fan exiting the house and wired in such a way as so it runs for the time during a shower and 10 minutes afterwards.
Old 02-06-2010, 07:53 AM   #6
ccarlisle's Avatar
Because you might have just as well asked a car forum "what's the best car?"...no one answer and not everyone wants to submit his claims yet again.
"How long is a piece of string" and all that...just know that the best paint will look like hell if the other aspects of painting are glossed over and a best painter can make even cheap paint look good. It is all the other elements that, in combination, give a good result.
In team sports terms, you need goaltending and defense and offense and balance and chemistry and coaching and desire to get a good result. No one element alone will carry you all the way.
Old 02-06-2010, 08:23 AM   #7
OK so where do I buy this Benjamin Moore's Fresh Start?
Also, I just put in a fan, the bathroom never had one before. I also bought a timer switch at Home Depot that has different time settings on it.
Old 02-06-2010, 08:59 AM   #8
ccarlisle's Avatar
At your local Benjamin Moore paint stores.
With the fan running the way it should and vented to the outside (not into an attic) you should not have mould problems down the road. Mould happens when humidity levels are such that mould finds a suitable substrate to grow on, providing there's no anti-mould product in the paint being used...
Old 02-06-2010, 09:02 AM   #9
I live in a small town, but I went to their website and a local building supply company carries it.
I will take your advice and use BM Primer, and 2 coats of Zinsser Perma White.
This will be going over new drywall, how many coats of primer? how long to let it dry before painting, and do I have to sand after priming before puting the first coat of paint on?
Sorry for all the stupid questions.
Old 02-06-2010, 10:42 AM   #10
I went to my local building supply, and they did not have Fresh Start, but he said he had Benjamin Moore Super Spec Latex Primer/Sealer...
He recommended that so that is what I went with, since that is the only place where I live that sells Benjamin Moore.
Is this a good primer to use before the 2 coats of Zinsser Perma White?
Old 02-06-2010, 11:00 AM   #11
ccarlisle's Avatar
Yes, that's fine. SuperSpec is a grade below Fresh Start, I think.
Old 02-06-2010, 05:18 PM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 386
yea, it is just not 100% acrylic but it will work fine. What I don't understand is why a BM dealer would not have Fresh Start?
chrisn is online now   Reply With Quote
Old 02-07-2010, 07:40 AM   #13
they had one kind of fresh start, it was oil based, and it was to cover stains.
Old 02-09-2010, 06:15 PM   #14
Tired, Cold, and Damp
slickshift's Avatar
Tack cloth, Dry-Type Swiffer, or Wooster Dust Eater
In all tests, vacuuming is effective, but not the best
Not much of diff. as regards to manufacturers
It depends...
For any color, the flattest look, and ultra-low VOC..
BM's Aura "Bath and Spa"
For "white", never mind the stink, but really effective, Zinsser's Perma-White
There are many other alternatives...
slickshift is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
