Best Primer Over Shellacked Floors And Nails? - Painting - DIY Chatroom Home Improvement Forum
Old 06-11-2011, 09:31 AM   #1
Best primer over shellacked floors and nails?
I ripped out the carpet in my old home (with the intention of refinishing) to reveal old wood floors which have been shellacked. No biggie, but the problem is the prior owners face nailed every #*&! board to every joist using common nails! They are also very splattered with white paint. After consulting some pro's the floors cannot be saved. SO, my plan is to paint them white. Sacreligious, I know, but I cannot afford to rip them out and put new ones down. My question is, what is the best primer to put over the wood that will also stick to the nail heads... I was looking at Zinsser, but I don't know which one to choose. Also, any advise on a durable brand of floor paint? I would prefer to stick with water based paints. Sorry for the long post, thanks!
jent7 is offline   Reply With Quote
Old 06-11-2011, 10:12 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
As yopu probably understand, it will be a maintenence floor , particulary in the wear areas.
But I would try Zinnser 123 ( scuff sand the floors the best you can, clean well.) then I like BM latex Floor and Patio . It has an eggshell like sheen so isn't too slippery, and will touch up nicely as needed. It is Epoxy reinforced.
Brushjockey is offline   Reply With Quote
Old 06-11-2011, 04:39 PM   #3
re:primer
Ive used BIN for trim etc.. and liked it alot; that is what I was originally leaning towards but I didn't know if it would stick to the paint splatters. How is 123 different? Also, does the 123 cover odors well? The wood is musty,I think I detect urine... Thanks, again.
Old 06-11-2011, 06:53 PM   #4
Bin would be the best, but you said you wanted waterborne paints. Bin is shellac based, thinned with denatured alcohol. Will stick to a shellacked floor like glue. Will hold back odors. Will be stinky and quick drying.
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
hammerheart14 (06-19-2011), jent7 (06-12-2011)
Old 06-11-2011, 07:00 PM   #5
I guess what I meant was "I don't want oil based" Thanks for your help, I really wanted a second opinion. Those were my thoughts, too. I will stick with the BIN and BM porch paint!
Old 06-11-2011, 07:12 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Don't understand why the floors can't be re-finished, as when you re-finish wood floors you sand and strip them down to new wood. There really is no primer for walking surfaces, as quality floor paints and enamels don't usually recommended using a primer. I would sand the floors down if you want to paint them to remove the majority of the varnish and open the woods pores. I would apply Sherwin Williams Treadplex floor enamel.
housepaintingny is offline   Reply With Quote
Old 06-11-2011, 08:58 PM   #7
I think the nails are why it can't be refinished. Wrong type, not set.
The Following User Says Thank You to Brushjockey For This Useful Post:
housepaintingny (06-11-2011)
Old 06-11-2011, 09:32 PM   #8
Rewards Points: 616
Thanks, I missed that part when I read the original post. That would make sense
Old 06-12-2011, 08:16 AM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
White is a tough color to keep clean...
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-12-2011, 08:29 AM   #10
color suggestions?
I hear ya, but we have no kids or dogs and don't wear shoes in the house.... What other colors do you suggest? Dark paints show every speck of dust, gray looks too much like a front porch for my taste and any 'color' is too much of a commitment for me.
Old 06-12-2011, 01:47 PM   #11
What if I used oil based?
I am now getting cold feet regarding using latex paint, I think that oil based would be more durable and a nicer finish. I went to SW and the guy recommended the industrial enamel (at 40% off). Do you think this is overkill? Also, I may be overthinking things here but the floors are old and wood expands and contracts- do I need to consider which paint is more 'flexible'?
Old 06-12-2011, 06:58 PM   #12
That's the best news I've heard yet. I don't like the idea of using a traditional latex porch/floor enamel inside. I have it, and it sucks. My office area is a one time porch, now enclosed, that still has the original floor. It doesn't wear well. With latex, you have the issue of nail heads flash rusting. I'm not sure what kind of barrier shellac is between rusted nail heads and latex enamel, as it does have a water component. Zinsser Cover Stain does not handle flash rust either. Will cover stain bond to shellac? I like Tom's suggestion of SW Tread-Plex, that looks pretty heavy duty. Might even get some for my floor.
how many nails per stud/plate joint? amakarevic Carpentry 4 01-05-2011 01:43 PM
Best wood/laminate floors for dogs jimithing78 Flooring 7 02-17-2010 02:02 PM
T Nails in top of HW floors, Sand/Poly over them? btodag Flooring 3 02-08-2010 01:07 PM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Is staining hardwood floors the best way for me to go? AndreaMB1978 Flooring 7 07-27-2009 02:08 PM
