Old 01-28-2013, 09:52 AM   #1
best primer for new drywall
I am having 3000 sq ft of drywall done in 2 weeks, and I need to have it primed overnight so they can come back and look for any flaws the next day... What do you guys think is the best primer out there to use? I have easy access to the following brands
Kilz
Valspar
Olympic
Sherwin Williams
Bulls Eye
Zinsser
This will be walls and ceiling, new drywall of course
besides the brand, how many coats of primer on new drywall?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 01-28-2013, 11:27 AM   #2
cdaniels's Avatar
I'm sure any one of these would work but IMO, the Zinsser Bulls-Eye would be best as it dries to a bit of a sheen and would show any imperfections more easily.It only takes one coat for a primer to do it's job.Two coats won't help it at all.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 01-28-2013, 11:54 AM   #3
Trucon01's Avatar
I like using the zinsser bulls-eye 1-2-3. covers nice, dries to a sheen, 2 coats of paint, done.
But this topic has been covered over and over. Do a search and you will see what others have said.
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 01-28-2013, 01:36 PM   #4
Gymschu's Avatar
Sherwin-Williams Drywall Primer
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
ltd (01-28-2013)
Old 01-28-2013, 05:18 PM   #5
paper hanger and painter
chrisn's Avatar
yes ^ one coat
or Bullseye123
forget the rest of the crap
Old 01-28-2013, 06:21 PM   #6
Roofmaster
Yup Bulls Eye. This stuff works very well for peel and stick tile too.
" A lot of men build things, and a lot of things fall down "
Old 01-30-2013, 09:36 PM   #7
Yep sherwin williams dry wall primer. for some reason they designed it for sheetrock. all others are good but I would use the one made for drywall.
Nailbags is offline   Reply With Quote
Old 01-31-2013, 09:08 PM   #8
Just realize it's primer not paint so it's not going to look like paint when it's done. It will look streaked and light in spots, this is normal for primer.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Nailbags (02-04-2013)
Old 02-04-2013, 06:05 PM   #9
Sherwin williams makes a great PVA Primer too seals the sheet rock.
Old 02-04-2013, 07:21 PM   #10
747
registered
747's Avatar
bullseye call around get best price. Maybe somebody got it on sale.
747 is offline   Reply With Quote
Old 02-05-2013, 04:27 AM   #11
chrisn's Avatar
no such thing, IMO
Old 02-05-2013, 07:24 AM   #12
Kilz
Valspar
Olympic
Sherwin Williams
Bulls Eye
Zinsser
I am a retired Union Painter with 30+ years service and I recommend
PVA,,, it is slightly transparent, meaning that you can still see the tape joints through it, but it is a good sealer, and cheaper than most Latex primers, for best results use a small Airless Sprayer with a 5-15 tip and be sure to roll after spraying, it's a 2 man job, 1 person spraying and one right behind him, rolling with a 3/4" lambs wool roller pad, this will insure uniform coverage. On NEW construction, I can prime ceilings and walls in a 3 bedroom/2 bath unit in under 4 hours using this method, NOW that is NEW construction where no light, switches, recepticles, plates or fixtures are yet installed. If you are using the same ceiling color throughout, then go back with your finish paint and do ALL ceilings with the same method starting in the FIRST room that you primed,, it should be dry enough to do. Then let the electricians install all fixtures, switches and plugs because all of the walls will need the Brush and Roll method! Hope this helps !
In 1, 8 hour day you have Everything Primed and the ceilings Finished!
Sherwin Williams PVA is good, whatever you decide to use make certain it is Latex or Acrylic,, Oil based primers on NEW sheetrock will make it FUZZY AND it will make a LOT of unnecessary SANDING !!
b679995 is offline   Reply With Quote
The Following 2 Users Say Thank You to b679995 For This Useful Post:
Nailbags (02-05-2013), ToolSeeker (02-05-2013)
Drywall Primer - What kind?I troyce1 Painting 6 01-25-2013 05:40 PM
Should Primer be Tinted on New Drywall?? My painter says no. Pete33 Painting 20 08-13-2012 11:24 AM
Best Primer for New Drywall? aigsrone Painting 21 06-29-2012 08:31 PM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 09:13 PM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 05:37 PM
