Old 06-28-2012, 12:29 PM   #16
Jack of all - master none
hyunelan2's Avatar
Best Primer for New Drywall?
Just throwing one more comment in the direction of Zinsser 1-2-3. I love that stuff.
hyunelan2 is offline   Reply With Quote
Old 06-28-2012, 01:08 PM   #17
I am kind of partial to the 1-2-3 also, and I would even probably consider it my go-to primer, but there are some primers from Ben & SW that are more specifically geared to new drywall, which is why I sent OP those links...
pucks101 is offline   Reply With Quote
Old 06-28-2012, 01:34 PM   #18
Thanks for the info! I would like to minimize the number of products I'm using. I'm going to change to the 123 for the painted walls, but is it the wrong thing for the new sheetrock?
JamesRW is offline   Reply With Quote
Old 06-28-2012, 01:50 PM   #19
You may get a lot of opinions for that question. I wouldn't say it's "wrong". I think it will do a job too; IMO, you just may notice that something made for new drywall specifically may spread just a little easier and cover a little more square footage. Other than that, I do not notice any difference in the finished, painted wall.
Old 06-29-2012, 04:54 PM   #20
Matthewt1970's Avatar
123 is actually one of the better latex primers on the market. It dries with a bit of a sheen (shine) so imperfections tend to stand out. Helps ya find the bad spots before you start throwing color on the walls.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-29-2012, 08:14 PM   #21
I just ordered Sheetrock First Coat.
aigsrone is offline   Reply With Quote
Old 06-29-2012, 08:31 PM   #22
Well, good luck! I decided to change to 123 - things are going much better, except the places where I had already used the First Coat. Going over that with the 123 is frustrating! It's like the First Coat turns to glue or something!
Too much wasted time with the USG First Coat!
The Following User Says Thank You to JamesRW For This Useful Post:
Brushjockey (06-29-2012)
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 09:13 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 05:37 PM
