Best Primer For New Drywall? - Painting - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 01:26 PM   #1
Best Primer for New Drywall?
What is the best primer for new drywall?
Also do i need to "seal" my new drywall? What does sealing do? Thanks.
cost not an issue. thanks.
aigsrone is offline   Reply With Quote
Old 06-26-2012, 02:25 PM   #2
Mr. Paint's Avatar
The answer depends on whether a spray texture is going to be applied. A drywall primer/sealer provides an even foundation and uniform porosity for texture or finish. Usually, these are a thin slurry, almost as if you mixed a primer with joint compound. USG makes one. I am more familiar with Hamilton Prep Coat.
For a paint system, a high-quality PVA primer will be fine.
Mr. Paint is offline   Reply With Quote
Old 06-26-2012, 02:33 PM   #3
I can't find USG primer anywhere in stores.
Sheetrock First Coat Primer
Old 06-26-2012, 03:59 PM   #4
no spray texture just a new drywall
Old 06-26-2012, 04:48 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Sorry but PVA primer is garbage. After you have used it your walls will look like nothing was even put on them. Do yourself a favor and use one of the multitude of primers on the market like Benjamin Moore Fresh Start Latex or Sherwin Williams Promar 200 Primer just stay away from PVA
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
ltd (06-26-2012)
Old 06-26-2012, 04:56 PM   #6
Mr. Paint's Avatar
I'm sorry that some painters have had bad experience with PVA primers. Quality ones are engineered with enough pigment to cover thoroughly, provide good adhesion, rust and mildew protection and give a positive seal. My company sells hundreds of thousands of gallons to small and commercial painters, all extremely satisfied with a good product and willing to invest the cost to reduce labor. Buy quality, not the cheapest thing you can get your hands on.
Old 06-26-2012, 07:58 PM   #7
what about killz primer?
Old 06-26-2012, 08:35 PM   #8
Rubbin walls since'79
Brushjockey's Avatar
Read the smooth wall thread below. He made a good choice..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-26-2012, 08:45 PM   #9
post link pls.
Old 06-28-2012, 12:19 AM   #10
Faron79's Avatar
Rewards Points: 260
Yes...PVA-class primers are OK at best, but if you used a better primer like Zinsser 123 or C2-One...you'd never go back to the PVA-stuff!!
It's KIND OF like comparing cheap/light painter's-plastic to 6-mil landscaping plastic!
Faron
Faron79 is offline   Reply With Quote
Old 06-28-2012, 11:12 AM   #11
Rewards Points: 121
Similar Question
We are working on an upstairs with 4 bedrooms, 2 baths, hallway & stairs. The bathrooms have all new sheetrock. The rest is painted sheetrock that was NOT primed before it was painted originally. It has various large patched areas (new drywall & mud), plus MANY smaller places where loose paint was removed or/and larger nicks were skim coated and sanded.
The drywall contractor swore by the USG Firstcoat, but after doing one bedroom and the hallway, (2 coats each), I am skeptical.
Is this stuff only good for the new sheetrock areas? How can I tell if it will bond the old and new paint? Why am I needing 2 coats of it? (Covering a dark maroon and dark green paint.)
Had it tinted, so can't return it - I think I want to change to 123.
JamesRW is offline   Reply With Quote
Old 06-28-2012, 11:18 AM   #12
Mr. Paint's Avatar
Manufacturers go to great lengths in naming their products to indicate their inted purpose. "First Coat" is just that; it is not intended for previously painted surfaces. It is intended for new gypsum board surfaces only.
I think in your situation Zinsser 1-2-3 Primer is a better choice. It also has enough pigment load to help covering deep colors.
Old 06-28-2012, 11:23 AM   #13
Rewards Points: 121
So should I go over what I have already primed with the 123? Better to do the extra work now than after the paint (I will be using either BM or Muralo - most likely a matte finish.)
Old 06-28-2012, 11:28 AM   #14
www.No-Curb.com
JohnFRWhipple's Avatar
My vote is for Zissner 'Cover Coat'. Bar None the best primer I have ever used for drywall priming. Once applied it can be sanded to a feather finish where most latex primers gunk up somewhat.
JW
"When it's Perfect. It's good Enough." - John Whipple
JohnFRWhipple is offline   Reply With Quote
Old 06-28-2012, 11:35 AM   #15
Mr. Paint's Avatar
You probably should put 1-2-3 on everything. This will ensure that the primed surfaces have even porosity/sealing and enable your finish to go on evenly.
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 09:13 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 05:37 PM
