Best Primer For Fiber Cement Siding? - Painting - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 03:28 PM   #1
Best primer for Fiber Cement Siding?
Hi, what primer should I use for Fiber Cement Siding?
Thank you for your Help...
JBTECH is offline   Reply With Quote
Old 02-02-2013, 03:36 PM   #2
Gymschu's Avatar
Rewards Points: 460
Most FC products come pre-primed. That being said, most painters don't trust the factory applied primer. I am partial to Sherwin-Williams Loxon Concrete and Masonry primer for any product that is cement based. You may want to buy a gallon and try it out first to see if it is going to be a problem solver for you.
Old 02-02-2013, 03:39 PM   #3
Thanks!!
Thank you I will try that, thanks for your help....
Old 02-02-2013, 03:43 PM   #4
How much does the primer cost?
I seen the price and is high for a gallon, is there any other good primer?? Thanks...
Old 02-02-2013, 04:22 PM   #5
Rewards Points: 13,256
Have you taken the time to down load the info from the James Hardee web site?
It's all right there.
Old 02-02-2013, 04:30 PM   #6
747
registered
747's Avatar
Rewards Points: 534
A top quality acrylic primer and Super Paint. You'll have a great finish.
747 is offline   Reply With Quote
Old 02-03-2013, 10:24 AM   #7
Rewards Points: 5,974
Your thread said the best primer not the cheapest primer not trying to bust your chops but there is a huge difference between the two. Besides if you search around there are coupons floating around for SW products that may put the price in a different light.
Old 02-05-2013, 07:58 AM   #8
OIL Base Primer for MOST exterior projects !
The Factory Primer would be Questionable to me, However, one thing for certain is, make sure the surface is clean and WAX free, they sometimes apply a thin wax coat to protect during shipping,
I read Mfg recommendations and if I can, I wash new siding that I am going to paint with TSP, Tri-Sodium-Phosfate,
I always use Oil based primer for exterior, and here's why ! Oil based primer takes a long time to dry and during this drying period, it has much longer to soak in, which causes WAY better gripping ability. Your Finish paint is no better than the Primer under it, meaning if the Primer comes off, the Finish is coming off with it, then you have RAW material exposed, many will probably disagree, but I am a retired, 30+ year vetran of the Paint game and this method seems to work best,,, don't misunderstand now, Latex is Fine for your finish, just use OIL BASED PRIMER for the best possible adhesion ! Blessings and Good Luck,,,, Steven
b679995 is offline   Reply With Quote
Old 02-07-2013, 03:29 PM   #9
Grants Painting's Avatar
Hardee Plank Paint
A100 primer from PPG then any topcoat. Its actually spec'd out for that. Many paints and primers can really damage Hardee board.
Last edited by Gary in WA; 02-09-2013 at 06:15 PM. Reason: removed web link per forum rules.
Grants Painting is offline   Reply With Quote
Old 02-08-2013, 11:12 AM   #10
Rewards Points: 394
As stated, an exterior acrylic primer is generally the recommended primer for cementitious siding. This can be topcoated with a 100% acrylic exterior finish.
Will22 is offline   Reply With Quote
Old 02-16-2013, 02:16 PM   #11
I never realized that PPGs was called A100, I know that is the name of a Sherwin Williams group of products !
Old 02-18-2013, 10:27 AM   #12
Rewards Points: 394
A-100 IS an SW product, not PPG.
Old 02-18-2013, 04:13 PM   #13
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You will want to use a primer intended for masonry surfaces,I would use Loxon masonry primer from Sherwin Williams.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Will22 (02-19-2013)
Need help choosing most reliable cement siding nordic587 General DIY Discussions 13 01-30-2012 09:04 AM
Measuring for Vertical Cement Siding Edward1 Building & Construction 0 02-20-2011 05:44 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
