Best Primer For Aluminum Siding? - Painting - DIY Chatroom Home Improvement Forum
Old 10-11-2010, 12:29 PM   #1
Hey, I've been hearing and receiving conflicting information in regard to using an oil based or water based primer for re-painting my aluminum siding. Some say use an oil based primer because water based has ammonia which will react with the aluminum and creat bubbles. others say in the past that was true but now the amount of ammonia in water based paints is so low that bubbling is not a factor. I'm confused and frustrated because I want to do it right the first time, you know? Any advice, suggestions on what type of primer.
dignan07 is offline   Reply With Quote
Old 10-11-2010, 03:06 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Aluminum siding only needs to be primed if you have bare aluminum. I would use a water base DTM bonding primer on any bare spots. I would use water base because unlike oil base it won't become brittle and crack down the road, it will expand and contract with the siding, and it can also withstand heat better than oil base. The important thing is to clean the aluminum well removing any chalky, oxidized aluminum. TSP works well for cleaning, but rinse well. We have always had great success painting aluminum siding using Sherwin Williams DTM bonding primer on any b are aluminum and then applying two coats of a 100% acrylic latex, our choice of paints for aluminum is Sherwin Williams Super Paint.
housepaintingny is offline   Reply With Quote
Old 10-11-2010, 03:56 PM   #3
Thanks for the info. I really appreciate it!!
Old 01-19-2011, 12:04 PM   #4
Citrix & Cisco Ops
I also had a few questions on this topic; thank you for answering some of them off the bat!
I'm planning to paint my house this summer, which is covered head-to-toe in aluminum siding. It's pretty old and starting to discolor in places, but is in good shape with no dings/holes/etc.
My chief complaint is every time it rains, water lingers on the clapboards, looks lousy, and takes a long time to dry out. (Pictured.)
So, a few quick questions:
-Will a fresh coat of paint help seal the surface and bead up water?
-Even with the baked-on color, is priming first a prudent thing to do? If so, is Latex-based primer ok, or should I definitely use water?
-I don't have a Sherwin Williams anywhere in my area, but I live near a Benjamin Moore store and Home Depot. What types of paint or primer from these stores would you recommend?
RedHelix is offline   Reply With Quote
Old 01-19-2011, 12:37 PM   #5
Rewards Points: 616
Primining the aluminum siding is not necessary unless you have bare spots of aluminum. The most important thing is to clean the surface properly getting any chalk and dirt off of the surface. I prefer to use a pressure washer, tsp, and a nylon scrub brush for this. after you will want to use a water base primer for any raw aluminum and a quality 100% acrylic latex paint, apply two coats. Do not use an oil base, as an oil base can not take the heat as well as a water base and also does not have elastic properties to expand and contract with the siding. We prefer Sherwin Williams DTM bonding primer and Sherwin Williams SuperPaint.
Old 01-19-2011, 04:07 PM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
Only thing I will add is to use Emulsabond in your first coat of paint.
Old 01-19-2011, 05:36 PM   #7
Gymschu's Avatar
Rewards Points: 460
^^^^^This is great advice! I have painted aluminum siding for 30 years & it always comes out great with Housepaintingny's advice. I have had great success using SW's Superpaint Satin. As for that watery discoloration, I think two coats of paint may help it bead up more rather than lay on the siding. A lighter color may also keep it from showing up so prominently.
Old 01-19-2011, 06:49 PM   #8
Citrix & Cisco Ops
Thank for you the additional info
What about the item regarding water beading? Can I expect any improvement with a fresh coat of paint?
Old 01-19-2011, 08:17 PM   #9
Rewards Points: 616
Thanks, that is how we always paint aluminum siding and other things that are aluminum. I've never had a problem using that method and using SW Superpaint. I would use a satin finish too and probably a lighter color
Old 01-19-2011, 09:54 PM   #10
Aluminum siding
-I don't have a Sherwin -I don't have a Sherwin Williams anywhere in my area, but I live near a Benjamin Moore store and Home Depot. What types of paint or primer from these stores would you recommend?
California Paint Exterior Satin will fix that right up
DGideon is offline   Reply With Quote
Old 07-26-2011, 09:58 PM   #11
Can i use "kilz" to paint aluminum siding? Will that work?
NFOHIO is offline   Reply With Quote
Old 07-27-2011, 12:17 PM   #12
Gymschu's Avatar
Rewards Points: 460
Kilz is an INTERIOR product as far as I know and shouldn't be used on exteriors.
Old 07-27-2011, 07:56 PM   #13
NACE Coating Inspector
mustangmike3789's Avatar
Do not use kilz. Do you have any bare aluminum or paint talking.
mustangmike3789 is offline   Reply With Quote
Old 07-28-2011, 06:25 AM   #14
Mike, does, uhm, does your paint talk to you?
Mine does too sometimes, I'm so glad it's not just me.
Old 07-28-2011, 10:53 AM   #15
stupid auto correct i have had some long conversations with paints and sprayers before. i think that the moderators would delete them if i posted them here.
The Following User Says Thank You to mustangmike3789 For This Useful Post:
jsheridan (07-29-2011)
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Exterior Primer for Wood Siding? Trish99 Painting 1 04-18-2009 12:46 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
