Best Paint Remover For Stripping Latex? - Painting - DIY Chatroom Home Improvement Forum
Old 04-29-2008, 08:49 PM   #1
Best paint remover for stripping latex?
What is the best paint remover for stripping old latex paint off wooden window trim? I have an extreme bleed through problem that no primer has been able to stop, and I need to get down to bare wood so I can prime. There are several layers of latex, primers, and maybe even some alkyd under all that. Also, how do I protect the window caulking next to the aluminum windows from the paint remover I apply to the wooden trim?
DanielP is offline   Reply With Quote
Old 04-29-2008, 09:05 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Unfortunately, there's not one stripper that works for everything
Even if you had good luck with one on an outside chair, it might not work at all on this interior window
It doesn't help that you've got multiple products to strip there
What works for the topcoat may be stumped by the primer
best to head on down to your local Paint Store and ask what's the best product available (don't bother asking for the "safest" or "least smelly", those won't help you)
The Paint Store will have the strongest available in your area (Big Box Home Centers Wal*Marts won't)
However, personally and professionally I see no reason to strip
A pigmented shellac will work against pretty much any bleed through
(though I suppose the worst possible case would be two or three coats)
If it doesn't work, the next step above that is window remover
slickshift is offline   Reply With Quote
Old 04-29-2008, 10:02 PM   #3
Pro Painter
Stripper won't eat through wax. Masking tape has a wax coating, so just mask the caulk.
joewho is offline   Reply With Quote
Old 04-30-2008, 07:21 AM   #4
RippySkippy's Avatar
Use a heat gun. At worst for the caulk...you may have to replace it, that shouldn't be a big chore tho...
RippySkippy is offline   Reply With Quote
Using Exterior Latex Paint fedx12 Painting 8 04-27-2008 01:19 AM
polyurithane over latex paint spharris Painting 3 08-27-2007 11:01 AM
Embarrassingly stupid question about latex paint joeyboy Painting 7 08-20-2007 09:25 PM
