Best Paint For Outdoor Wood Table (stain Resistance)? - Painting - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 09:11 PM   #1
best paint for outdoor wood table (stain resistance)?
I have an outdoor wood table for the backyard that is painted white.
Over the years, the paint has become stained from bird droppings and other outdoor contaminants, where even scrubbing with a bleach solution didn't get the table entirely clean.
A few weeks ago I decided to repaint the table with a can of white spray paint. It came out really nice but now again it's starting to get stained by outdoor contaminants (most likely bird dropping residue).
I'm sure many will recommend to paint the entire table another darker color so stain's won't show. Before I do this, I'm wondering if there is something I should look for in an outdoor paint (spray or brush-on) that would resist permanent stains from outdoor contaminants.
thanks
techman41973 is offline   Reply With Quote
Old 10-07-2011, 12:08 AM   #2
A Little Of Everything
Rewards Points: 1,364
Spray paint is definitely not the way to go. I'd suggest you scuff it, prime it, and go with a good quality gloss paint (I'm not going to argue brand names here). There is no such thing as perfect, when it comes to stuff like bird poop with mulberries, but gloss paint will probably be your best bet.
DrHicks is offline   Reply With Quote
Old 10-07-2011, 03:05 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 304
You got that right
Old 10-07-2011, 11:11 AM   #4
If your current wood table top is flat enough, and after paint dries completely, you could try using a glass table top made to size. The bird poop can be cleaned off glass. Tossing horse shoes in the direction of a glass topped table might be a problem.
Polly
Polly003 is offline   Reply With Quote
Old 10-07-2011, 03:43 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
.. a picnick table cloth might be a little safer, and cheaper.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-07-2011, 03:45 PM   #6
Pfffttt... Sure, go the cheap, easy & logical route!
Old 10-07-2011, 08:11 PM   #7
Bird droppings with berries, purple droppings, permanently stained my car's clear coat, twenty five years ago, when paint was paint. Good Luck. Move the table.
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 10:50 AM
Stain a large concrete patio (or paint?) ArizonaJay Painting 1 11-14-2010 01:02 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
paint or stain weathered cedar siding daynat Painting 1 06-02-2009 10:03 PM
