Best Paint For New Interior Doors... - Painting - DIY Chatroom Home Improvement Forum
Old 08-06-2013, 07:34 PM   #1
Rewards Points: 153
Best Paint for new interior doors...
Hi and thanks,
We have new interior solid core doors that came preprimed.
Looking locally for someone to spray them.
I am under the impression they will need to re prime them with a good primer then 2 coats of paint.
Color is dark brown, almost black, low sheen like satin.
My question is for you pro's ..
What would be the paint suggestion here ? Have access to all of the stores and did not know if there was one better than the other ...
Looking for that "kitchen cabinet" type finish..
Thanks and time is appreciated.
beachfront71 is offline   Reply With Quote
Old 08-06-2013, 07:55 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
I'd first see what the painter recommended and why. As a pro I would sort of resent a HO going on some site and asking when they didn't know my procedure or choices and why..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
chrisn (08-07-2013), Gymschu (08-07-2013)
Old 08-06-2013, 08:07 PM   #3
kwikfishron's Avatar
Rewards Points: 598
Originally Posted by beachfront71 View Post
Hi and thanks,
Personally... I like and use BM Aura for doors. I don't think you can wrong with that.
kwikfishron is offline   Reply With Quote
Old 08-07-2013, 02:35 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Listen to brush
Old 08-07-2013, 06:15 AM   #5
Rewards Points: 5,974
Also agree see what he recommends and why. Don't think I have ever seen kitchen cabinets in a low sheen. Seems like low sheen plus dark color on doors which are fingerprint magnets anyway would be a bear to keep clean.
Old 08-09-2013, 12:42 AM   #6
Rewards Points: 16
If you're hiring it out, you might as well ask for a conversion varnish or a 2K polyurethane. No reason to not go with a commercial product.
Trekker is offline   Reply With Quote
Old 08-09-2013, 07:12 AM   #7
Gymschu's Avatar
Rewards Points: 842
Trekker, OP, is wanting to PAINT them.
Old 08-09-2013, 08:52 AM   #8
Rewards Points: 16
I assumed that "paint" = "pigmented finish". Most factory "painted" finishes are not what a consumer would call paint. Take a look at Sherwin Williams OEM line for pigmented finishes for things like kitchen cabinets and interior doors. Heck, what you call "paint" on your car probably a catalyzed urethane.
Old 08-09-2013, 01:00 PM   #9
Mr. Paint's Avatar
Factory primers are a cheap product, usually thinned and sprayed on. They supposedley keep the new product from drawing moisture while shipping and the marketing department can declare them Pre-Primed! Hence, to build a good foundation for your finish, a quality enamel undercoater is usually applied first.
If you elect to go to a plural-component system, be careful. Use a test patch to ensure nothing lifts the factory primer. Some products will be compatibile while systems like conversion varnish or "hot" polyurethanes will act as paint remover.
Good luck with your project!
The Painter's Paint Store where QUALITY is ECONOMY
Mr. Paint is offline   Reply With Quote
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
