Best Paint Marker To Use On Rubber - Painting - DIY Chatroom Home Improvement Forum
Old 04-29-2008, 08:13 PM   #1
Best paint marker to use on rubber
Hi all,
I got a small rubber part that i need to put a small color dot on it (very much like the dot on squash ball).
Tried a few types of paint markers, but the marker will not stay and peel off easily.
Rubber is NBR, black, about 80 shore A, need to have different colors. The color dot i need to put on it is about 1 to 2 mm in diameter.
Any suggestions? Thanks in advance.
Cheers
Teck Beng
pronate is offline   Reply With Quote
Old 04-30-2008, 06:49 AM   #2
Try getting some dye.Used to do graphics on rubber, dye was what worked for me in that application.
mark942 is offline   Reply With Quote
Old 05-01-2008, 07:24 PM   #3
Thanks. Specifically what type of dye do you mean? Can you tell me the brand you used before that worked? Appreciate the help.
Old 05-06-2008, 06:52 AM   #4
http://www.parasolinc.com/dyes_paints.asp
BEHR Paint Problem Please advise PaintPro Painting 14 05-12-2012 11:15 PM
What's your "favorite" tip, when using "oil base" paint? Bobrobert Painting 15 01-17-2008 10:36 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
my painter did not fallow the contract jaskoo Painting 17 11-19-2006 01:21 PM
