Old 10-26-2010, 02:14 PM   #1
best exterior paint for asphalt roof in TX
where to purchase and how is it applied and the roof prepped?
I'd like to try it on the back half of house about 450 sq ft.
seems harmless and would be less expensive than radiant barrier or metal roof
just as white clothes, umbrella, hats, and cars are cooler is the concept.
gails.shells is offline   Reply With Quote
Old 10-26-2010, 03:46 PM   #2
Painting Company, NY
housepaintingny's Avatar
We like to use Kool Seal roof coating and it can be used on asphalt. You can spray it or use a thick nap roller to apply it. http://www.kelloggspainting.com/Roof-Coatings.html
housepaintingny is offline   Reply With Quote
Tags
asphalt roof, exterior paint
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
