Best/easiest Way To Remove Wall Paper Paste? - Painting - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 12:44 PM   #1
Best/easiest way to remove wall paper paste?
I've just finished taking the wallpaper off in my bathroom using a steamer. It was fairly easy but their is paste all over the walls. My walls are sheet rock and it looks like there's a layer of paint under the paste. What is the best way to take the paste off? Thank you.
tdeepness is offline   Reply With Quote
Old 07-03-2013, 05:04 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
http://www.safeandsimple.com/
Old 07-03-2013, 07:59 PM   #3
Rewards Points: 4,796
If the paper came off with just a steamer, then you should be able to get the glue off with hot water too. Sponge wet, scrape with putty knife, sponge off. Cover potential residue with Gardz.
jeffnc is offline   Reply With Quote
Old 07-04-2013, 03:33 AM   #4
chrisn's Avatar
Rewards Points: 504
If it is glue on there, then hot water will have 0 effect
Old 07-04-2013, 07:01 AM   #5
Rewards Points: 5,994
Originally Posted by chrisn View Post
if it is glue on there, then hot water will have 0 effect
say it ain't so.
Old 07-04-2013, 04:46 PM   #6
chrisn's Avatar
Rewards Points: 504
Originally Posted by ToolSeeker View Post
say it ain't so.
The gentleman from NC said it first
Old 07-06-2013, 12:48 AM   #7
Whether it's "glue" or "adhesive" doesn't matter. If hot water got the wallpaper off, then hot water will continue to get the adhesive off. Otherwise you are saying that hot water dissolved the adhesive underneath wallpaper, but fails to dissolve the adhesive once the wallpaper is gone, which makes no sense.
Old 07-06-2013, 02:28 AM   #8
chrisn's Avatar
Rewards Points: 504
Just to be clear, you are the one who was picking on another member for saying he put a cleaning solution "in" a power washer.
All I was saying is that it was not glue
Old 07-06-2013, 03:49 AM   #9
I suggest you to wipe with warm water if that walls are made of tiles or ceramics or else you can use stain remover and can stripper those paste off.
phiferindia is offline   Reply With Quote
Remove part of conc basement wall stadry Concrete, Stone & Masonry 13 04-17-2013 04:25 AM
Remove wall at recessed window boogie81 Building & Construction 7 04-06-2013 03:07 PM
Can I remove this wall..? (Image) findlay70 Building & Construction 8 04-27-2011 05:02 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
