Best Ceiling Paint? - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 10:29 AM   #31
It's a fairly large bath. I'm more concerned with the mildew. I'll go with the silver eggshell. thanks.
Old 02-27-2011, 08:57 PM   #32
Thanks to all who replied. I went with the Zinsser Perma-White. It does say low odor on it, and although there is a smell, if it goes away in a week or less I can live with it.
I have redone 2 bathrooms (one finished and the other close) and I noticed the fan in the first one does not remove a lot of the moisture after a shower, so I may redo that one as well.
gravespinner is offline   Reply With Quote
Old 02-28-2011, 06:06 AM   #33
Retired
Edgar214's Avatar
Excellent choice.
Mike
THE ONLY THING THAT'S CONSTANT IS CHANGE
Edgar214 is offline   Reply With Quote
Old 02-28-2011, 02:38 PM   #34
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
That would be the the wisest thing to do
Old 12-21-2011, 02:54 PM   #35
Originally Posted by jsheridan View Post
Fran, what you need is less high hiding paint and more flat paint. Don't know where you live or what's available to you. I like Ben Moore Super Spec flat, BM Muresco, or BM's new waterborne ceiling flat, MAB Fresh Kote Flat, Finnaren & Haley Carefree Flat. Specify to your dealer that you need dead flat. Not all flat wall paints are good for ceilings. You want the least sheen possible, dead flat. Get a good quality 1/2 cover or lambswool, apply the paint generously and uniformly. Roll one half of the ceiling two roller widths, then do the other half two widths, overlapping side to side and back into the previous rolled area. Go back and forth in this fashion across the whole ceiling. Back and forth.
Are there any updates on which ceiling paint (for new primed walls) is best NOW? It seems paint and brands come and go in terms of quality or they're re-branded under a new name. I have a lot of ceilings to paint near term.
Also, I have two different whites I'm considering, depending on what color is in that room. Do the PRO's paint a lighter or brighter white knowing that it will appear darker to the eye vs. what they see on a paint chip or just looking into the can? The thought came to me yesterday after looking at my coffee white paint chip and the can lights in the one room. It's all down light with some light reflectiing off the top of the walls and objects in the room back into the ceiling... the ceiling and walls will be seperated by a lighter colored 4" crown molding.
TIA,
James
jawadesign is offline   Reply With Quote
Old 12-21-2011, 03:16 PM   #36
Rubbin walls since'79
Brushjockey's Avatar
Jawa- sometimes it really helps to prime new ceilings first- dont brush first- roll as tight as you can with the primer and cut after. Seems like the first thing to hit a new ceiling will always show- and brush banding is hard to get rid of.
Then I would use any of the BM ceilings that JS said- super spec or BM waterborne ceiling if it is a color- Muresco if just a ceiling white.
The primer will help the finish spread more evenly and faster.
If you don't know about 18" rollers- ceiling work is a great place to use them. ( or 14, which I use but need to be special ordered)
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-21-2011, 03:56 PM   #37
Thanks BJ,
So are you impartial to using SW products? I only bring it up because I was leaning towards their products, they are more willing on price than BM.
PrepRite 200 (primer)
Brilliance (ceiling paint)
I planned on using 12” rollers as much as I could, the 18’s seem too large to keep a steady stroke, at least for me. I guess I could cut and trim a 18” roller to a 14”, giving me a 4” as touch up roller. But that may get pricey unless I clean, spin or bag my 14” rollers each day.
Any comments on going to a shade lighter in terms of white, ie ultra bright white will appear just white on the ceiling, especially at night with table lamps on.
James
Old 12-21-2011, 04:07 PM   #38
I don't use SW , so I can't comment so much on them. Not saying that they don't have good products, but where I am BM rules the pro repaint and Dec market.
What is your wall color- and why do you think you need a overly white ceiling? All the above will disperse light well, flats are intended to not be reflective. All will also be plenty white, but you can split hairs on degrees.
BTW- the Super spec flat is a contractor grade- good price. I wouldn't like it for walls- but it does work well for ceilings. - I have used SS eggshell extensively for walls before the new mattes came out.
Old 12-21-2011, 04:47 PM   #39
I was just making sure you didn't have a bad experience with a specific SW product...
My kitch/entertainment room 11x25 walls will be a soft (light) yellow, white trim with dark (mocha) colored kitch cabinets. Not sure whether I'm going wtih a light or dark countertop yet. I don't want bright white trim next to the darker colored cabinets. I prefer a more yellow, off-white color on the room trim (coffee white (BEHR) to be specific), with a polar bear white on the ceiling. I was going to go with a darker (wht) on the ceiling, but after bringing the large color chips into the room I changed my mind. After holding up the chips near the ceiling I noticed the polar bear white looked the same as the darker coffee white in the horizontal position. This is why I ask the question, should I go with an ultra bright white (flat) ceiling paint and call it a day?
I know the wet paint, chip and actual paint applied will always appear different. I never realized the 50 avail. shades of white could make such an impact until I started picking out interior colors!!
James
Old 12-21-2011, 04:57 PM   #40
The one part about all that I would say- is don't use Behr for your trim. While in many minds it is less than "optimal" for walls- it has really bad blocking ( stickiness) problems on trim. Don't skimp for trim- because a little goes a long way.
If you need that color- take it to SW and get Pro Classic WB satin matched.
The trim will appear a little lighter due to it being a sheened paint- will reflect light more. But it will also be more of a focus than the ceiling.
One way of dealing with it that decs will use, is use the same color- different sheens for ww and ceiling. They will look different as explained, but will not fight in color.
The keep it simple technique..
Old 12-21-2011, 06:13 PM   #41
ltd
Rewards Points: 536
here's what i use on all my ceilings, s/w super paint. in extra white flat my trim is super paint semi in the same color, if i want to get fancy ill go pro classic on the trim,but you have to know what your doing with that paint. anywho i ask my clients what they want on the ceiling and trim and we always go extra white ,never a second thought. i cant remember the last time i used anything but extra white. if you do want to tweak it a little look at dover white .
ltd is offline   Reply With Quote
Old 12-22-2011, 01:46 PM   #42
BJ, I agree. The BEHR and in my experience GLIDDEN both have a tack to them, even after a few years of drytime... lol! But I made the mistake of buying 4g of polar bear white and 5g of coffee white, both non-refundable!
So I plan on using them... I have a ton of trim, plan to spot strip it, oil prime those areas and use Gripper basically everywhere else after scrubbing it clean. It's worked for me so far. If someone wants to feel up my crown molding or base boards, that's their prerogative, lol!
LTD, thanks for the input. My plan was to use SW-Brillance-ceiling paint. Any reason you use the SW superpaint over the brilliance?
Interesting that you both mention same white, but different sheens for ceiling and trim. It does make sense though!
James
Old 12-22-2011, 11:03 PM   #43
ltd
Rewards Points: 536
yea brilliance is a good paint for ceilings its what painters call a dead flat paint meaning it wont show any imperfections. super paint flat has a very slight sheen that is only noticeable looking at it at a slight angle.what this does is it makes it a more durable paint so imo its the best of both worlds beautiful and durable. you might say well how durable does a ceiling paint have to be? i don't know
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 10:16 AM
peeled ceiling paint off, how to fix? philosophical Painting 3 10-19-2010 05:28 PM
Ceiling hairline Cracks and New Paint sw8689 General DIY Discussions 9 11-11-2009 12:43 PM
Is ceiling paint special? SR996 Painting 2 03-27-2009 05:51 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
