Old 04-02-2007, 10:14 PM   #1
Is it best to caulk new moulding edges before painting?
Getting ready to totally redo my livingroom. Pull carpet, Refinish hardwood floors, new base/crown mould ...and paint walls, ceiling and moulding.
Is it better to run a bead of caulking along the edges of the base and crown moulding before painting?
I was hoping to pre-paint all the moulding and just put them up, but if I should be caulking things. I will need to paint it all in place.
Davo is offline   Reply With Quote
Old 04-03-2007, 12:59 AM   #2
made in U.S.A.
Hamilton's Avatar
If possible, all paintable caulking should be completed during the primer phase. Caulking should not be applied after the finish coat as it will yellow and attract dirt, and in time will look bad.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 04-03-2007, 03:16 AM   #3
Pro Painter
It's best to do after priming, for performance purposes.
Second option is to paint it,hang it, caulk it and touch it up, for apperance purposes.
For a single room, you might just as well paint it after it's hung. If painted first, you'll still have to fill nail holes and touch up anyway.
You could get lucky and everything will be tight and not need any caulk.
joewho is offline   Reply With Quote
Old 04-03-2007, 11:27 AM   #4
Tired, Cold, and Damp
slickshift's Avatar
Caulking should be done after priming (or after first coat...see next line)
If the molding is being primed and first coated off the wall, then the final coat should be with it in place, after (installing and) caulking
slickshift is offline   Reply With Quote
Old 04-03-2007, 05:55 PM   #5
Home Improvement Guy
ron schenker's Avatar
[QUOTE][You could get lucky and everything will be tight and not need any caulk./QUOTE]
Ya..really, really lucky
ron schenker is offline   Reply With Quote
Old 04-03-2007, 10:35 PM   #6
OK thanks....
Put up moulding
prime moulding
caulk moulding
paint moulding
Old 04-12-2007, 04:57 PM   #7
Davo how are you going to fasten the moulding?
Are yougoing to putty?
jmthouston is offline   Reply With Quote
Old 04-14-2007, 06:37 PM   #8
Moulding will be nailed and countersunk holes will have putty/caulk.
Old 04-15-2007, 12:12 AM   #9
made in U.S.A.
Hamilton's Avatar
Don't caulk over nail holes, use spackle or spot putty. Caulk & sandpaper don't mix.
Whatcha thinka NOT painting interior moulding white? Davo Interior Decorating 7 07-07-2007 08:58 PM
crown moulding painting WorkOnIt Painting 3 06-18-2007 11:56 AM
Bathtub Caulk billinak Remodeling 17 05-27-2007 09:34 AM
Caulk Windows eric s General Discussion 2 11-26-2006 09:45 PM
