-   -   Is it best to caulk new moulding edges before painting? (http://www.diychatroom.com/f4/best-caulk-new-moulding-edges-before-painting-7517/)
Davo 04-02-2007 09:14 PM
Getting ready to totally redo my livingroom. Pull carpet, Refinish hardwood floors, new base/crown mould ...and paint walls, ceiling and moulding.
Is it better to run a bead of caulking along the edges of the base and crown moulding before painting?
I was hoping to pre-paint all the moulding and just put them up, but if I should be caulking things. I will need to paint it all in place.
Hamilton 04-02-2007 11:59 PM
If possible, all paintable caulking should be completed during the primer phase. Caulking should not be applied after the finish coat as it will yellow and attract dirt, and in time will look bad.
joewho 04-03-2007 02:16 AM
It's best to do after priming, for performance purposes.
Second option is to paint it,hang it, caulk it and touch it up, for apperance purposes.
For a single room, you might just as well paint it after it's hung. If painted first, you'll still have to fill nail holes and touch up anyway.
You could get lucky and everything will be tight and not need any caulk.
slickshift 04-03-2007 10:27 AM
Caulking should be done after priming (or after first coat...see next line)
If the molding is being primed and first coated off the wall, then the final coat should be with it in place, after (installing and) caulking
ron schenker 04-03-2007 04:55 PM
[QUOTE][You could get lucky and everything will be tight and not need any caulk./QUOTE]
Ya..really, really lucky
Davo 04-03-2007 09:35 PM
OK thanks....
Put up moulding
prime moulding
caulk moulding
paint moulding
jmthouston 04-12-2007 03:57 PM
Davo how are you going to fasten the moulding?
Are yougoing to putty?:huh:
Davo 04-14-2007 05:37 PM
Moulding will be nailed and countersunk holes will have putty/caulk.
Hamilton 04-14-2007 11:12 PM
Don't caulk over nail holes, use spackle or spot putty. Caulk & sandpaper don't mix.
