Belle - Painting - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 01:13 PM   #1
Belle
Post
Belle
We decided to paint our yucky looking textured ceilings. They need it: the house is 30 years old and they have never been repainted. Trouble is, when we started the drywall finish came off in one place in a sheet.So we stopped, andnow there's a clean white patch with a 6 inch by 3 inch patch in it! Is there anything special we need to do before repainting?
Belle is offline   Reply With Quote
Old 04-02-2009, 02:03 PM   #2
Remodeling Contractor
You may need to remove the texturing. Paint also protects the surface. With no maintenance done for so long the surface is shot. Spray water on the texture and scrape it all off. Skim coat with drywall compound so you cover all the digs and scratches on the surface. Sand smooth. Prime with a PVA primer. Paint with two top coats of a quality paint.
Old 04-02-2009, 05:16 PM   #3
Belle
OK. Ignorance here. What maintenance do ceilings need? Just regular painting? For the next time we build (never again).
Old 04-02-2009, 05:17 PM   #4
Clean as needed. Paint every 3- 5 years.
Old 04-02-2009, 06:09 PM   #5
Belle
Post
Ceiling maintenance
OK. Guess I'm stuck. I cleaned it every once in a while, but, like I said, this is our only painting. I'm disabled, and I have to drag my boys, kicking and screaming (ok,not quite, now that they are older), into helping. I can only do the low parts. Thanks for your help.
Old 04-02-2009, 06:16 PM   #6
Use a quality paint so you do not have to do this again. If only one small area has fallen apart, then try to patch to match with drywall compound. Then use a 1/2" nap roller and prime with latex and paint with a Benjamin Moore ceiling paint.
Old 04-03-2009, 12:09 AM   #7
Belle
OK, you are giving me some hope here..... Prime with WHAT KIND of latex, as in brand. We had bought Dutch Boy ceiling paint to do the job. Is Benjamin Moore that much better?
Old 04-03-2009, 07:09 AM   #8
Their premium lines are.
