Behr Water Based Paint On Table - Painting - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 11:11 AM   #1
Behr water based paint on table
How do I smooth this out? the water based protective caoting turned white, not clear. Can I sand this and apply non water based polyurethane or clear rustoleum?
allkar9245 is offline   Reply With Quote
Old 06-03-2011, 12:16 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
please provide a little more info and pics if possible. sounds like moisture entrapment in the coating. did you apply it too heavy? wait on recoat times? is it white or really cloudy?
mustangmike3789 is offline   Reply With Quote
Old 06-03-2011, 08:23 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
You need to mix the can well before using. Water based poly will have a milky color to it while it is still wet. This is due to the polyurethane resins that are used to produce the varnish. This color should go away as it dries and the molecules coalesce. putting on thick layers can cause cloudiness. Water based varnish is partly an evaporative finish, so it needs oxygen to cure. By putting on thick layers the finish will always dry from the top down. If the top dries too fast then the finish below will take much longer to dry and may cause problems down the road. Simple solution is to use more thin layers.
Millertyme is offline   Reply With Quote
Old 06-03-2011, 08:32 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
I went back and read post again, and I am confused. Are you using a varnish or paint?
My Review: Valspar vs Behr vs Olympic vs ColorPlace Achilles97 Painting 85 01-20-2017 09:56 PM
Water based painted over oil based paint Konalady Painting 0 10-03-2010 08:10 AM
Water based paint for driveway Bam79 Painting 3 08-04-2010 01:02 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
