Behr Solid Stain Is Peeling, What Can I Do? - Painting - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 04:21 PM   #1
Behr solid stain is peeling, what can I Do?
I put Behr solid stain in white on my deck railing years ago. It started peeling off in sheets like paint after one year. It remains on many of the smaller spindles. To get it all off I would have to strip and sand and this could take all summer. Should I just scrape it down untill nothing is loose and apply an oil based stain over it? I would go with white again as it is still mostly white, although I would prefer gray.. I would like to use a semitransparent this time so that it wears away instead of peeling.Will this work or will I just make more of a mess?. I cannot afford a proffessional to scrape it all off.
ktyms is offline   Reply With Quote
Old 05-03-2012, 04:24 PM   #2
Rewards Points: 150
With the correct stripper it will come right off and you will be ready to coat it with new sealer. You do have to neutralize after you strip it. Either way you have to remove all the old stain. You should look for an oil based sealer as it will penetrate and not just cover the wood.
CaptRandy is offline   Reply With Quote
Old 05-03-2012, 05:00 PM   #3
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Also, be sure you are not putting it on too thick. That's a problem I've had in the past. Too thick and it will bond to itself and just flake off rather than bond with the wood.
hyunelan2 is offline   Reply With Quote
Old 05-04-2012, 05:50 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I'm not sure if they are still doing it, but Behr use to put silicone in their stains. It was highly prone to failure for whatever reason and would often peel very quickly. The problem is that it never peels off completely. It stays spotty like you are seeing. The other problem is that the product had silicone in it and nothing else likes to stick over top of it. I'd recommend getting it completely off and never using Behr again. It isn't a good quality product.
Darkling Designs
poppameth is offline   Reply With Quote
Old 05-04-2012, 06:01 AM   #5
Oh no, another thread for the ages!
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (05-05-2012)
Old 05-04-2012, 08:41 AM   #6
Rewards Points: 150
I see Behr and see $$$$$$$. Strip, Strip, Strip.
Old 05-04-2012, 04:47 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
I'm sure you have noticed how quiet I have been
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (05-05-2012)
Old 05-05-2012, 09:08 AM   #8
The same thing happened to me. They offered to replace the stain and give me some sort of stripper and a bottle of deck cleaner. I told them no thanks, and got the money for a gallon of stain instead.
I paint boats for a living, and I'm quite sure I didn't do anything wrong. It was pretty disappointing. I won't be using their stuff again.
almostnormal is offline   Reply With Quote
Old 05-05-2012, 05:28 PM   #9
Deck stains should never have a build up on the surface. They are stains, not paint so they should be a penetrating type coating. It seems like the viscosity or thickness of the product was to heavy for a solid color stain. There are deck stain strippers on the market, so one of those may help remove some of the old finish.When applying deck stains, put only what the wood will accept, no more, and certainly no build-up.
paint boss is offline   Reply With Quote
Old 05-05-2012, 09:26 PM   #10
What kind of wood is the railing? Some species don't take very kindly to latex, and that solid / semi-transparent stain might be latex-based.
pucks101 is offline   Reply With Quote
Composite exterior door - stain peeling! darthsmozers Windows and Doors 4 03-20-2012 06:39 PM
Trying to stain with Behr Concrete Dye brandon55 Flooring 0 06-19-2011 10:56 AM
Help! Peeling stain nurselaurenc Painting 12 06-12-2011 11:48 AM
Yucky peeling acrylic solid stain Angie S Painting 1 04-17-2011 09:37 PM
BEHR House stain llengele Painting 2 03-03-2011 03:42 PM
