-   -   Behr Latex Stain (http://www.diychatroom.com/f4/behr-latex-stain-42660/)
loyal 04-17-2009 07:17 PM
Behr Latex Stain
About 8 years ago I painted the cedar siding with the behr latex barn red
exterior stain. I power washed the house first. (It had already been painted with some kind of similar stain by the previous owner. Only a different color.)
I never primed it, just power washed. Now it's starting to peel in some spots.
Mostly on the east and west sides of the house.
I'd like to use the same brand and color of stain but have it done right this time.
Just what is the right way to do this?
Scuba_Dave 04-17-2009 09:38 PM
Buy another brand besides Behr
Matthewt1970 04-18-2009 12:57 AM
Stain shouldn't peel. Most people who use Behr Latex Stain have it peel off the next year. You now have a painted surface. Unless you can get most of it off, you need to jus scrape the peeling spots. Prime the bare wood and paint.
chrisn 04-18-2009 05:45 AM
Buy another brand besides Behr :thumbup:
"better to leave the walls bare than put Behr on the walls":yes:
sirwired 04-18-2009 06:57 AM
While Behr stain isn't great stuff, my wife put the Barn Red Latex on her house (before I met her) and it lasted for seven years with only some chaulking on the side that got the most sun. There was no peeling.
Yes, no coating should chaulk that quickly, and it was indeed low-quality stuff, but it is an exaggeration to say that "Most people who use Behr Latex Stain have it peel off in a year."
I suspect here it needed to be washed with something other than just water; scrubbing with house wash was probably necessary.
SirWired
loyal 04-18-2009 05:33 PM
Any recommendations as to what brand I should use?
Would still like to use the water based stuff.
What about the primer? what brand/kind would you guys recommend?
loyal 04-19-2009 06:42 PM
Olympia Maybe?:boat:
KillzIt? :gun_bandana:
Matthewt1970 04-19-2009 11:04 PM
Don't prime if you are going to stain.
e-behr 05-08-2009 02:24 PM
loyal
I am sorry to hear that the paint is peeling from the siding on your barn. I work for the Behr brand and we want to make sure that all of our customers are satisfied with their purchase.
Peeling could be a result of improper temperature conditions, surface preparation, or exposure to moisture as it cures. Without knowing more details on the application of the product, I am not able to say exactly what could have cause this.
To fix damaged areas, sand the damaged areas down to a tight surface. Then clean surface with mild liquid detergent, rinse and let dry completely. If large areas are peeling, it may be necessary to strip the surface to ensure proper adhesion to the topcoat. Once dry, you can then apply Behr’s Barn and Fence paint (which is a self priming product) or a solid wood stain.
If you would like detailed instructions on application and preparation of the cedar siding, please email us directly through the BEHR website at www.behr.com
Hope this helps!
e-behr
Behr Web Communications
Matthewt1970 05-09-2009 12:24 AM
Or it could be the cheap latex paint being called stain......
loyal 05-09-2009 12:10 PM
Well ok.
But so far no one has suggested a better brand.
And it would have to match the barn red color that's
already on the house. Seems to me, after reading
all the posts, that the best thing to do would be to
scrape the loose stuff, sand edges some and then
re-stain.
But any input would be welcome.
Matthewt1970 05-09-2009 02:29 PM
Sikkens is a real good brand. The problem you will have is if you have "paint" on the surface then stain will not be able to do it's job and that is to soak in.
loyal 05-09-2009 03:35 PM
I think that I'm finally starting to understand.
The Behr Solid "stain" is actually not stain but latex paint. Right?
So before I could apply a real solid stain onto the cedar siding,
I would have to remove all the Behr stuff.
Am I finally geting it?
phoenix 07-30-2009 05:26 PM
Re: Behr solid color stain red
i have to disagree with behr solid stain peeling off after a year...i used the barn red color on both new and stripped 100 year old cedar planks with no problems for over 3 years... i stripped the old wood with heat guns, chemicals and sanders....it will proably be another 2-3 years at least before i completely scrape the entire 1600 sq ft craftsman, but when i'm done it will be beautiful..thanks to behr and no, i am not affiliated with them in any shape,form or faction:thumbsup:
loyal 07-30-2009 06:47 PM
Thanks for the reply.
Actually I ended up using the same Behr
barn red that is already on the house.
I didn't think it was that bad either.
After all, the only prep I did before
I applied it the first time was to
power wash it.
And it still lasted about 8 years.
It seems to cover much better
now. Goes a lot farther.
I'm thinking that they may have improved
it since the last time I used it.
