Beginners Painting Mistake - Painting - DIY Chatroom Home Improvement Forum
Old 07-30-2007, 07:41 PM   #1
Beginners painting mistake
Hi,
For my first paint job I accidentally used Glidden Ultra-Hide Interior/Exterior Alkyd Semi-Gloss to paint my room.
I don't know a lot about painting or paints in general, but I painted the room with half a can, on July 8th. It's been over 3 weeks and the smell has gone down but now gone away. I tried moving in this weekend but after 30min to an hour my throat gets sore and the smell gets to me.
To combat this I have had 2 box fans in the windows doing a push pull wind tunnel effect to the room (when I can, for at least a week, I close the windows on days when the AC is on). I also put 2 onions in water, 2 bowels of vinegar, and 1 box of baking soda. I'm not sure how much this has helped.
Any suggestions on how to make the VOC's dissipate quicker would be appreciated. Would a heater in the room help? Can I cover the paint with primer and paint over with latex?
Thanks - John
Warder45 is offline   Reply With Quote
Old 07-31-2007, 10:21 PM   #2
Paint/Faux Artisan
Da Vinci's Avatar
This is a tough one because paint is on already. A great trick before you paint with oil is put a few tablespoons of vanilla extract in it. It will smell more like a bakery than paint. You could try this and put on a second coat to seal fumes.
The other option is to sand oil, prime with water based zinsser 123 and use low voc latex enamel like SW Pro Classic.
Bay Area Painting Company
Da Vinci is offline   Reply With Quote
Old 08-01-2007, 04:02 PM   #3
Workaholic's Avatar
Rewards Points: 268
Activated charcoal is an option as well.
Sean
Workaholic is offline   Reply With Quote
Old 08-01-2007, 09:45 PM   #4
Paint/Faux Artisan
Da Vinci's Avatar
How much would work in this situation Workaholic? I've never tried that one- I assume you can buy that at a pet shop that sells aquarium supplies?
Bay Area Painting Contractor
Old 08-02-2007, 01:26 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
The Glidden is a bit whiffy
Fresh air is the best you can do
If you are still sensitive to the smell, which really should be dissipating by now, sealing in the Glidden may be the best course
As it's oil, and semi-gloss, you'll have to sand, dust, and oil prime, then coat with a Top Quality Interior latex paint....and I would suggest one of the low odor/VOC premium lines from Ben Moore, Sherwin Williams, or Pittsburgh
slickshift is offline   Reply With Quote
Old 08-02-2007, 02:26 PM   #6
Rewards Points: 1,910
Maybe it's those bowels of vinegar
Seriously, I wouldn't add any more layers of anything. It will just add more stink or slow down the release so it lasts longer. Keep airing it out and be glad that winter is a long way away so you can keep those windows open.
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
How to identify a good painting contractor? firsthomegal Painting 8 09-17-2007 06:11 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
Painting exterior of house crebive Painting 2 05-27-2006 11:53 AM
