Beat To Death! Wallpaper - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 05:35 PM   #16
Originally Posted by Brushjockey View Post
A tiger lover comes out of the closet! lol
I use 30 grit sandpaper
Certainly did, and with passion as well. That has to be a record number of words in a Chrisn post, if you don't include the quotes. I awoke a sleeping tiger. Want to buy my tiger's teeth. I think I'll let go of his tail now, and run.
Old 10-26-2011, 04:05 AM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 294
You cannot out run a tiger
and yes sandpaper works well also
Old 11-02-2011, 06:55 PM   #18
self help
Alright tigers...
Got done with the slimy mess the wallpaper left me. It was a mix of Dif, and water/vinegar. I thought the WV mix worked better than the Dif. I sprayed, waited about 10-15 mins then scraped it off with my DW knife.
Hit the walls with a pole sander real quick. Just got done rolling out the Gardz (can't call it paint). Not sure if I got enough on but I can smell it so I know its up.
I was planning on putting some thin paneling (mdf) and have stiles go up to top rail. I need some help if I should do that or just nail in frames on the current dry wall. The top of the wall will be wallpaper. Also what should I do with all the trim while Im working on a room? I plan on replacing and matching the whole house but I can't do it all at once. Should I remove it before I continue with the job or leave it up?
bigjon is offline   Reply With Quote
Painting over wallpaper - no other option - How to proceed kuj0317 Painting 15 07-25-2011 04:25 AM
Wallpaper removal or primer? Should I put up new wallpaper instead? Aqua Painting 1 04-06-2011 04:36 AM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 12:13 AM
