Old 12-28-2011, 11:12 AM   #1
bathrooms
I have semi-gloss paint on my bathroom ceiling and I think it's causing my walls to sweat. And now I'm starting to see mold. We have a window in the bathroom. We just painted with this semi-gloss on the ceiling. Walls never sweat before. How do I remove the semi-gloss paint?
emckea is offline   Reply With Quote
Old 12-28-2011, 11:31 AM   #2
home renovation expert
bathrooms
Paint over it
ridge-runner is offline   Reply With Quote
Old 12-28-2011, 11:50 AM   #3
Super Moderator
bathrooms
Turn on a fan--the humidity from the paint drying is causing the problem--
If the paint is dry then the wall sweating has nothing to do with the ceiling
Old 12-28-2011, 04:51 PM   #4
An old Tradesmen
bathrooms
Any chance the bathroom fan just happens to no longer be working?
Old 01-01-2012, 05:24 PM   #5
ARC Painting's Avatar
bathrooms
Install a fan!
The paint needs time to cure (few weeks), before it will stand up to moisture properly, and constant showers are going to slow that down. Is it a water-based bathroom paint? This is the most mold resistant. The paint itself is not causing sweat; the semi-gloss is providing a good seal against moisture in the wall. Before it probably just absorbed into the wall (which is worse for mold!)
ARC Painting is offline   Reply With Quote
Wiring inline bath fan for multiple bathrooms secutanudu Electrical 27 08-24-2012 03:38 PM
Browse New Generation Bathrooms Design & styles bathroomsuk Plumbing 0 09-20-2010 02:38 PM
Need advise with these bathrooms zxc1251 Off Topic 1 08-25-2010 07:49 AM
Remodeling bathrooms - is this wiring plan overkill? spidrw Electrical 10 03-23-2010 12:30 PM
supply runs required in all bathrooms? bjherron HVAC 2 11-23-2007 08:56 AM
