Bathroom Window Sill - Painting - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 03:36 PM   #1
Bathroom window sill
Can I use waterproof paint on a bathroom window that's in a shower. The sill keeps chipping from old paint. Can I just sand
and paint with drylock?
1janski is offline   Reply With Quote
Old 09-25-2012, 03:46 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
No, that is meant to be used on very porous cement/masonary.
Windows in showers are trouble.
Best i can tell you is scrape all loose material away, prime raw wood with an oil, then I would slather on a thick coat of Peel Stop, Making sure to have caulked any openings between wood components and anything else ( with PAINTABLE caulk..)
Then top with a hi quality acrylic trim paint 2x. And keep dry while doing all this...
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (09-26-2012)
Old 09-25-2012, 09:02 PM   #3
Gymschu's Avatar
Rewards Points: 932
I would make a strong case for replacing the sill with some pvc and you wouldn't have to worry about peeling paint ever again.
The Following User Says Thank You to Gymschu For This Useful Post:
joecaption (09-25-2012)
Old 09-25-2012, 10:30 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
I would have to second that.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 09-26-2012, 03:42 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
and third
Old 09-26-2012, 03:50 AM   #6
Too Short? Cut it Again!
I would vote yes also but hold the phone. If the sill is getting water damaged, what is happening to the framing under or around it? Is the sill angled to pour water back into the shower (I doubt it) or outside (maybe perhaps). If water is doing more than peeling paint and pooling, the window should be removed and replaced with drywall material, sealed glass block, or something.
I have been known to have clients buy an extra shower curtain and have a window treatment sewn for it. Helps divert the water from the window framing but does not alleviate the concern I expressed. Showers should not have windows in them. Skylights maybe.
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (09-26-2012)
Window shrink film around sill? Liv2123 General DIY Discussions 4 01-31-2011 08:10 PM
Replacing window sill, but now it's stuck. rosemonster Carpentry 25 01-25-2011 04:31 AM
What filler should I use between a window frame and sill Rachel39 Interior Decorating 2 08-02-2010 03:51 PM
Installing New Bathroom Window 1L243 Building & Construction 4 01-26-2008 11:40 AM
