Bathroom Painting, Need Info About Dfferent Paint - Painting - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 07:42 AM   #1
Bathroom painting, need info about dfferent paint
I filled in paneling in a bathroom and then painted it with primer and semi-gloss, it had flashing here and there. I resanded, touched up with joint compound. I was thinking of going with a flat washable paint in the bathroom or something other than semi-gloss? Do you always use semi-gloss in a bathroom? I really need to know this before I do anything else in that room.HELP! LOL
annibelle is offline   Reply With Quote
Old 03-10-2012, 07:46 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
No, either one of these or any Kitchen and Bath product from a real paint store will work fine. Just noticed that the SW is in Semi gloss so forget that one
Old 03-10-2012, 07:50 AM   #3
chrisn's Avatar
Rewards Points: 224
OK, forget the Sherwin and get either Ben Moore or Zinnser
Old 03-10-2012, 09:05 AM   #4
Gymschu's Avatar
Rewards Points: 460
The only paint I would NOT use in a bathroom is FLAT. Flat tends to "crackle" in a bathroom or any room where moisture is present. A quality Satin would work just fine. As always (well, almost always) Chris is on the mark.
Gymschu is online now   Reply With Quote
Old 03-10-2012, 05:32 PM   #5
chrisn's Avatar
Rewards Points: 224
say what?
Old 03-10-2012, 07:51 PM   #6
Yep, guy at Benjamin Moore paints said same thing. Thanks, I haven't painted yet. My brother brought me some light beigh satin finished Valspar and I may used that. It is a nice color and I was going to use some decorative painting in there I could still use the semi-gloss and may mix a little of it with the same brand and color of a flat. Hopefully, if I stir it real well it would blend well enough to use in smaller area. I will mix up a small batch first. The Valspar was mismatched paint for 5$ and it was 2 gallons of it and these seem to be a perfect match color wise, so I will want to use it somewhere. I am too frugal not too. Thanks,
painting brick on top of existing paint / water proofing basement 2md Painting 8 12-14-2010 11:11 AM
Paint Bathroom Ceiling questions? Hypochondriac Painting 5 08-15-2010 05:51 AM
Bathroom Paint - Crying Sap? stevencrider Painting 4 08-12-2010 07:21 AM
Painting Bookshelves - what type of paint? justin2009 Painting 9 01-05-2009 10:18 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
