Bathroom Paint Removal - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 07:18 AM   #1
Just purchased a home that needs many walls to be improved. Most concerning is the bathroom wall that has high gloss paint peeling from where bubbles burst. Was able to remove sheets of elastic color down to the drywall. However, it does not peel off in all areas so I have large patches of removed paint mixed with existing color. How do I remove the remaining color or should I just sand over existing color, then prime and paint? THANKS in advance.
Heartwoode is offline   Reply With Quote
Old 02-22-2011, 08:11 AM   #2
Coatings Nerd
Sand any edges, depending on how many coats of paint there are, you may need to skim coat the damaged areas, you'll have to determine that. Lightly pole sand the high gloss, then prime and paint. I would use a bonding primer, such as Benjamin Moore Fresh Start, on Insulx Stix. ( two good ones ) Brand doesnt really matter as long as its a "bonding" primer. Finish can be whatever you like provided there is no moisture or mildew problems.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-22-2011, 08:42 AM   #3
NCpaint1, I'm a novice and need help with vocab. What is skim coat and what is pole sanding?
Old 02-22-2011, 08:50 AM   #4
Coatings Nerd
Skim coat is a thin coat of joint compound to fill in any low areas. Depending on how many coats of paint are on the wall that have come off. Will it be noticeable once the edges are sanded smooth? If so then you may need to even that area out with a thin coat of drywall mud ( joint compound )
Pole sanding is exactly that.... a hand sander, on a pole Just makes it easier when you have a whole wall to do, instead of using a sanding block and climbing up and down a ladder.
Old 02-22-2011, 07:26 PM   #5
NCpaint1, THANK YOU. I get it now.
Tags
bathroom paint removal
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Paint recommendations and finish questions EJacobs Painting 2 09-03-2008 10:38 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Choosing paint for bathroom CowboyAndy Painting 3 04-04-2008 04:49 AM
