Bathroom Paint Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 06:37 PM   #1
Question
bathroom paint peeling
My home was built in 1994. In my boy's bathroom, I have a 8 inch high and 5 foot long window approx. 6 inches above the tub enclosure. It is well above the shower head, and it is inset and cannot be opened. Its function, I suppose, was to be somewhat like a sky-lite. The problem is the wall area between the tub enclosure and the start of the drywall "ledge" where the window is inset. So far, the wall is fine, but the 4 inch wide "ledge" that forms the inset has had repeated water over splash. Plus, my boys, stash their shampoo there (they can reach it - I can't!) The paint the previous owners used was semi-gloss (they left the paint can). I usually just stand on the tub edge and reach up and clean the ledge, but today I put a small step ladder in the tub to get a good look. The paint is peeling, and there is a small 2" x 3" area where, when I cleaned, the paint came off down to the drywall and metal edging. The metal edging has slight rust in a small area, but the main problem is the drywall is soft in the 2x3 inch area. I cleaned it well, removed the paint that was peeling and I am letting it dry. My question is...do I sand the rust off, spackle the slight dip in the drywall, paint with a Kilz type primer and then paint with bathroom paint? I plan on repainting the entire bathroom with bathroom paint, so I want to get this right. Any help will be really appreciated!
jenchip is offline   Reply With Quote
Old 05-14-2010, 07:27 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by jenchip
...My question is...do I sand the rust off, spackle the slight dip in the drywall, paint with a Kilz type primer and then paint with bathroom paint? I plan on repainting the entire bathroom with bathroom paint, so I want to get this right. Any help will be really appreciated!
You seem to have a firm grasp of/on the situation
Though rather than a "Kilz"-type primer (although Original oil-based Kilz might work OK), I'd suggest an oil/alkyd primer from BM or SW for this app.
slickshift is offline   Reply With Quote
The Following User Says Thank You to slickshift For This Useful Post:
jenchip (05-15-2010)
Old 05-17-2010, 10:47 AM   #3
Zinsser makes good oil and shellac based primers that r considerably less expensive that would work equally as well.
noboru wataya is offline   Reply With Quote
Old 05-17-2010, 11:29 AM   #4
I'm clueless when it comes to painting, but I'm having the same issue in my bathroom. Is there a water-resistant paint that is specially designed for bathrooms and situations like this?
RDD_1210 is offline   Reply With Quote
Old 05-17-2010, 12:11 PM   #5
If you use Kilz Premium primer in the gold can it will work great in a bathroom. It is great for sealing, stainblocking, especially in bathrooms. I used a Kilz Casual Colors paint with Satin finish over the primer, which can be painted over in an hour. The worker at walmart told me that using a kilz color chip and kilz paint it would cover in only one coat, it did just that. The paint also says mildew resistant on the can too but is not a specifically bathroom paint, but says the use is great for bathrooms. I've had no problems and it was easy.
BJeezy23 is offline   Reply With Quote
Old 05-17-2010, 10:58 PM   #6
slickshift's Avatar
True, Zinsser makes some excellent products as well
Old 05-17-2010, 11:06 PM   #7
slickshift's Avatar
We mentioned solvent based primers and sealers in this case for their rust preventative properties, and their vapor barrier properties
All that splashing is seeping into the walls, pealing paint (most likely from behind), and rusting the edging
Kilz Premium is a latex product and those do let moisture through
This particular (extremely wet) project calls for a good oil/alkyd (or even alcohol/shellac) based primer
Old 05-17-2010, 11:14 PM   #8
slickshift's Avatar
Yes, most companies have "bath" paints
Zinsser's Perma-White (eggshell, satin, semi-gloss) is very good
But it doesn't tint well beyond light pastels
BM's K&B (Kitchen & Bath) is just as good, tints to slightly deeper, but only comes in satin
BM's Aura Bath & Spa (matte finish) is the top dog for adhesion, moisture and mold & mildew resistance, scrub-ability, etc...and can be tinted to anything
Of course, the B&S costs more, but depending on you needs and desires it could be just the ticket
All are "self-priming", but in a case like this (special circumstances) it's best to do the proper prime, and use the self-priming paint over it for added protection against peeling
Old 05-18-2010, 10:00 AM   #9
Old 05-18-2010, 11:52 AM   #10
Originally Posted by noboru wataya View Post
do u just go through threads agreeing or disagreeing with everyone's posts? what's going on here?
He's a Moderator on this site & has been a member for 5 years
As Moderators we do review/read a lot of threads & posts
And in many cases do comment when we have knowledge or experience on the topic being discussed
That's what going on here...
Old 05-18-2010, 12:09 PM   #11
Newbie Bill
Rewards Points: 522
Before painting, does the drywall need to be repaired/replaced?
Since the boys are using this as a shelf, it is going to get wet, alot, even though it isn't in the shower spray.
If it was me and I was planning on living in the home for awhile, I would repair if necessay, paint as described above. Then I would try to find some sort of waterproof shelf to put on top of that drywall ledge. Maybe like a piece of granite. Perhaps with a bit of an overhang and a bit of slope and caulk around the edges.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-18-2010, 12:13 PM   #12
oh ok. couldn't tell if he was an admin or moderator. that's for the information.
as for the attitude, i could do without it. i don't care if he/she is a moderator. is it their job to second/validate good information all day?
i've noticed a lot of obnoxious/condescending posters on here so far. does painting piss ppl off, or talking about painting? is it ok if i question things sometimes?
i was just trying to grasp the reasoning behind it. SORRY!!!!!!!!
Old 05-18-2010, 05:33 PM   #13
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
You could do some adjusting yourself
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
drtbk4ever (05-18-2010)
Tags
bathroom , drywall , paint , water damage
Paint Cracks in the Bathroom Ceilling MajikOne Painting 2 11-10-2009 04:16 PM
Existing paint peeling gundy09 Painting 1 08-31-2009 10:46 AM
Painting over flat paint in bathroom lewisj Painting 2 03-17-2009 04:12 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
