Bathroom Paint - Painting - DIY Chatroom Home Improvement Forum
Old 08-31-2006, 07:07 AM   #1
bathroom paint
The wife and i recently painted the bathroom and now im noticing the walls are starting to peel in places (small chips)Is there a cirtian paint for moist conditions like bathrooms or kitchens?
rick32 is offline   Reply With Quote
Old 08-31-2006, 10:18 AM   #2
Paperhanger/painter
ProWallGuy's Avatar
Zinsser's PErma White or SW Kitchen /Bath or Ben Moore's K&B will work well in humid areas. But you must address the problem of the peeling paint first. Determine why its failing and correct it.
ProWallGuy
Professional Wallpaper & Paint Co.
ProWallGuy is offline   Reply With Quote
Old 08-31-2006, 01:05 PM   #3
They're all fixer-uppers
J187's Avatar
Rewards Points: 506
I really liked Sherwin WIlliams Bath paint when I used it. I painted my actual shower wall right above the fiberglass surrond. It gets direct water and has held up perfectly. Cleans easy.
J187 is offline   Reply With Quote
Old 09-24-2006, 08:50 PM   #4
Painting Contractor
What probably happened is a combination of moisture and hair products on the walls. This is a very common thing in bathrooms. The walls should have been washed thoroughly before priming and painting. Sounds like you need to chip away and sand all the peeling areas and maybe the whole surface real well (maybe with a palm sander and some 150 grit) and spot prime the areas that were peeling. The paints that were mentioned are great. I've used the Perma white by Zinsser and the Sherwin Bath Paint....
Paintguy26 is offline   Reply With Quote
Old 09-24-2006, 08:57 PM   #5
I'm with prowall and paint guy..... 1st find out the reason....(could even be the air freshener spray) then the product.
kellstar painting is offline   Reply With Quote
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Bathroom paint Color ssla Interior Decorating 10 07-15-2011 02:24 AM
Cracking Bathroom Paint tros080 Painting 3 07-05-2007 10:19 PM
Bathroom paint problem ERIK2173 Painting 3 05-22-2006 11:22 PM
