Bathroom: New Paint Is Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 11:44 PM   #1
bathroom: new paint is peeling
bathroom paint peeled
pdx timbers is offline   Reply With Quote
Old 05-21-2013, 05:04 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 392
that had a built in primer.
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (05-21-2013)
Old 05-21-2013, 05:24 AM   #3
What cleaner did you use? The pic with the light switch looks like it went down multiple layers and may be an unrelated failure.
Old 05-21-2013, 06:28 AM   #4
Jmayspaint's Avatar
Rewards Points: 534
Looks like what can happen with latex over oil. Maybe there was an old oil enamel on the walls, that even with sanding, the new latex didn't bond to. Some places(the different wall) could have already been painted once with latex, your latex would have bonded to it, but it wasn't bonded to the original either.
Cleaner residue could potentially do that, but wouldn't explain why some pulled off the layer beneath it.
You'll have to remove the loose stuff and start over if you want a good bond. After removing the paint, clean/sand it again with a cleaner that won't leave a residue. Alcohol maybe. Then prone it with a bonding primer designed to make the transition from oil to latex.
Jmayspaint is offline   Reply With Quote
Old 05-21-2013, 07:05 AM   #5
Gymschu's Avatar
Rewards Points: 832
Do we have to say it over and over? Does someone have to die before homeowners will believe us? DON'T USE BEHR PAINT!!!
Old 05-21-2013, 07:13 AM   #6
Jmayspaint's Avatar
Rewards Points: 534
Headline: Local man takes fatal fall in bathroom. Apparently he slipped on a paint chip because the Bher paint he applied fell off the wall. : jester:
Old 05-21-2013, 07:22 AM   #7
Rewards Points: 5,974
Next time use PRIMER. Real primer. Not to be a smart @## but take your pics back to the HD and ask what they can do to help with the problem, then come back and post the reply. This is just to reenforce why we preach go to a real paint store. I'm sorry you had problems but the only thing I can see is sanding and starting all over.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Jmayspaint (05-21-2013)
Painting over flat paint in bathroom lewisj Painting 2 03-17-2009 04:12 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
