Bathroom Mold!! - Painting - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 01:33 PM   #1
Question
Bathroom mold!!
I need to know what the best way to cover the leftover stain from mold on my bathroom ceiling! When we bought the house the ceiling was a wonderful gloss white, turns out they must have just painted before we bought cuz the stains sooned returned. We installed a fan and usually open a window after showering but are still stuck with the stain after scrubing the mold?? Any suggestion? repaint? Drop ceiling?? i was trying to avoid tearing it down and re drywalling.
jperschka2 is offline   Reply With Quote
Old 01-29-2010, 02:13 PM   #2
Send a message via AIM to Schweinehund
Have you tried Kilz? Zinnser makes a good stainblocker too.
Schweinehund is offline   Reply With Quote
Old 01-30-2010, 06:53 AM   #3
I haven't tried Kilz b/c I have heard mixed reviews about it and even B4 that I still have to tackle the peeling paint from the moisture. Do i try to scrape cuz I know not all of its going to come off and then its going to look so uneven.
Old 01-30-2010, 01:00 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
You will need to scrape any loose paint. I would then use Kilz as long as all the mold is dead. Then use joint compound if the surface is uneven.
Old 01-31-2010, 11:52 PM   #5
Faron79's Avatar
Rewards Points: 260
Close the window!!!
This usually amazes me...the thinking that opening a window will help get moisture out... It makes it twice as bad...especially in cooler weather.
Question: After a shower the air is warm/moist. Outdoor air is COLD & DRY.
Guess what happens when these air-masses meet??
Answer: LOTSA condensation IN your bathroom, that wouldn't be there if you kept the window shut, and let the fan get the moist air out.
Problem-multiplier:
SO...if the fan is running, window open, bath-air still moist...
You're pulling in more cold air, allowing even greater condensation...
Ya see where I'm goin' with this?
2nd issue:
I'd consider new drywall up there.
* Key words here..."By the time you do xxx"....
* Yes, you could do a drop ceiling. BUT...the root issue is still up there...possible wet drywall & mold on top of it.
* Then, you'd have a new ceiling, with any "behind-the-scenes" issues corrected. AND, peace of mind.
(still....keep the window shut!!!)
Faron
Faron79 is offline   Reply With Quote
Painting a bathroom and removing mold Ztien777 Painting 5 01-06-2010 07:50 PM
Newbie with Bathroom Mold question KellyDuHomeReno Remodeling 1 12-06-2009 09:54 AM
Bathroom mold problem ACB123 General DIY Discussions 4 08-18-2009 12:08 PM
Mold around bathroom tub 99miles General DIY Discussions 1 08-15-2009 06:51 PM
Window in Bathroom Shower: MOLD roztom Building & Construction 25 08-27-2008 05:42 PM
