Bathroom Ceiling Problems - Painting - DIY Chatroom Home Improvement Forum
Old 07-25-2014, 03:01 AM   #1
bathroom ceiling problems
about 3 months ago I painted my bathroom ceiling with a flat white paint that came from Walmart.It looked fine for about 6 weeks then I noticed it was flaking off in spots.6 weeks later it is falling off the ceiling.I know it was latex over latex so why didn't it bond?
WishInew is offline   Reply With Quote
Old 07-25-2014, 03:17 AM   #2
Painting contractor
Rewards Points: 341
Your first mistake was using "el cheapo" paint from Wally world. always use a quality paint from a paint store. Secondly, it could have happened for a number of reasons.Just because they were both water based paints doesn't guarantee adhesion.Probably wasn't properly prepped.
Red Dog is offline   Reply With Quote
Old 07-25-2014, 06:31 AM   #3
Gymschu's Avatar
Rewards Points: 832
Red Dog is right. Without knowing your prep work, we really can't help you much. Do you have adequate ventilation in the bathroom? Is there a working fan that exhausts air from your bathroom to the exterior of your home? Was the ceiling cleaned and dry before painting? After showers is there heavy moisture on the walls and ceiling? Lots of factors at work here. Could be just about anything. Flat paint in a bathroom is not always the best answer.
Gymschu is online now   Reply With Quote
Old 07-25-2014, 11:49 AM   #4
Thanks for the replies guys and Red I have learned my lesson on " value paint"....lol. The flat paint was easy to remove as it was falling off by itself.I have done my research and found the proper prep procedure and will be using a bonding primer and a quality satin this time. Probably SW Bath Paint.
Old 07-25-2014, 11:59 AM   #5
Painting contractor
Rewards Points: 341
Sounds like you got it right now WishInew. If you are on a budget and have to go with a less expensive paint you are so much better off to go with a mid grade paint store paint like the one you are going to use.Lesson learned the hard way but learned nonetheless. Don't forget what Gymshu said about the moisture.Best of luck to you.
Peeling paint on bathroom ceiling NadiaHD Painting 1 04-16-2012 03:56 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Bathroom Ceiling jcv400ex Painting 4 12-25-2010 11:53 AM
HELP! Ceramic tiled ceiling in basement bathroom.... jrutherford Remodeling 1 10-11-2010 12:27 PM
