Bathroom Ceiling, To Prime Or Not? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 04:28 PM   #16
Send a message via Skype™ to kutsyy
Originally Posted by chrisn View Post
I know I said I use 3/4 NAP most all the time, but you have to remember( or at least know) I have done this day in and day out for more than 20 years. I would NOT recommend this to a DYI. You should be using a 1/2 nip at most
I've been using 3/4 for a while and I like it, so I'll continue using it
kutsyy is offline   Reply With Quote
Old 01-04-2012, 04:31 PM   #17
Just wanted to say, thanks everyone.
I still have not figure out if I will or not use primer, but see as it goes. Part of the repainting is to redo lighting/fan & crown moulding, so it may depends on how tired I will be....
Vadim
Old 01-04-2012, 05:06 PM   #18
Sorry Vadim, reread your orig post and can't see how I missed the Bath part of the Aura. I walked around the other day looking for my phone for a few minutes, then realized it was in my hand. So, missing bath is fairly insignificant in the scheme of things. Anyway, unless you have bare substrate, you really don't need any primer. Good Luck, keep us posted.
Old 01-04-2012, 05:08 PM   #19
NP, thanks for all of the recommendations.
Old 01-04-2012, 05:44 PM   #20
Too Short? Cut it Again!
Chris our love of 3/4" nap roller covers will meet at some point.
For me it is part the sound I guess. Rolling nice quality paint from a 3/4 nap cover sounds different than that horrible noise thinner roller covers make.
You will try one on cabinet doors, with poly tossed in....someday.
Old 01-04-2012, 05:58 PM   #21
Could you post your home address. Some of my Asian American friends just want to show up and make you some tea. I promise they only will ask you to qualify the concept of using 1/2 nip. They will leave if, in person, you just say typo.
Chris-san. Having tea made for you is very spiritually enlightening. You will not be hurt.
Old 01-05-2012, 03:36 AM   #22
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
[quote=sdsester;812574]Chris our love of 3/4" nap roller covers will meet at some point.
You will try one on cabinet doors, with poly tossed in....someday.[/quote]
don't hold your'e breath
chrisn is online now   Reply With Quote
Old 01-05-2012, 02:29 PM   #23
a surface should always be clean, dull and dry but priming is never a bad idea then you know you will get max adhesion and make sure the primer will stick to glossy substrate.
shives is offline   Reply With Quote
Old 01-06-2012, 01:56 PM   #24
Although you don't need it, if you want a better job that is going to last much longer, I would recommend using primer before you add your two coats of paint. The color will also be more accurate if you put down primer before adding your desired color.
Phillies48 is offline   Reply With Quote
Bathroom ceiling and walls HELP! Maia Painting 13 02-21-2013 03:21 AM
HELP! Ceramic tiled ceiling in basement bathroom.... jrutherford Remodeling 1 10-11-2010 12:27 PM
Bathroom and textured ceiling painting? elementz Painting 6 10-01-2010 04:27 PM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 09:20 AM
finishing a bathroom ceiling mmhendrie Building & Construction 8 03-25-2009 03:01 PM
