Bathroom Ceiling Bubbled - Painting - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 09:20 PM   #1
Electrician
Proby's Avatar
Bathroom ceiling bubbled
About three years ago, after I bought my newly paint house, the paint on the bathroom ceiling bubbled. There is no water leak from above, but I do take really hot showers and it's a small bathroom. These bubbles are just the paint that isn't sticking to the plaster. It hasn't cracked, it's just flexible paint hanging down a little bit, I can push it up but it falls right back down. Oddly enough, it's stayed like that for 3 years, it never cracked or anything.
Since I will be re-doing my tub I figure I'll also repaint the ceiling. I assume I have to rip these bubbles off and keep scraping until all the loose paint is off, then sand the transition smooth, is that correct?
Second, what type of paint should I use to avoid this happening again?
The paint that they used to paint the ceiling and walls is just typical Sherwin Williams semi-gloss white paint that you'd use on molding.
Proby is offline   Reply With Quote
Old 07-17-2010, 10:29 PM   #2
Rewards Points: 85
I had a similar problem once with my small bathroom. I scraped off the bad areas and patched them, and then repainted the whole ceiling with bathroom paint. No problems since, and it's been 13 years.
Regular latex will allow moisture through, and that ruins the bond beween the paint and ceiling. Bathroom paint blocks the moisture.
MrBill_DIY is offline   Reply With Quote
Old 07-18-2010, 05:41 AM   #3
DO you have good venting in this room?
mark942 is offline   Reply With Quote
Old 07-18-2010, 09:05 AM   #4
Electrician
Proby's Avatar
Yes, I installed a Panasonic exhaust fan a few months after I moved it. At that time there were already some bubbles, however, more have developed since installing the fan.
Old 07-18-2010, 10:02 AM   #5
You might want to try using a de-humidifier in the room. Then when you see little to no water build up in the tray, then paint. There may be a lot of water built up in your walls as a result of no venting. Just a thought.
Old 07-18-2010, 10:19 AM   #6
Electrician
Proby's Avatar
I installed the exhaust fan (oversized for that size bathroom) 2 1/2 years ago. There could still be water build up from back then?
Old 07-19-2010, 05:56 AM   #7
"""""" Since I will be re-doing my tub I figure I'll also repaint the ceiling. I assume I have to rip these bubbles off and keep scraping until all the loose paint is off, then sand the transition smooth, is that correct? """""""""
You also might want to use a spackle, then sand smooth. Prime in a oil primer, then top coat in latex.
But I would be really concerned about why the paint bubbled in the first place. How long do you use the fan when using the bath/shower? 15 to 30 minutes is pretty much the norm after use.
Old 07-19-2010, 08:59 AM   #8
Electrician
Proby's Avatar
I have a timer, the fan runs for 10-15 minutes after the shower.
I figured the paint "fell off" the ceiling simply because it is not the right paint for a bathroom.
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 08:08 PM
Bathroom ceiling repair floridagirl General DIY Discussions 6 11-29-2009 09:56 PM
Bathroom Ceiling chadfran Painting 11 06-19-2009 08:55 PM
finishing a bathroom ceiling mmhendrie Building & Construction 8 03-25-2009 03:01 PM
bathroom ceiling material? mayhem69 General DIY Discussions 1 12-26-2008 05:09 PM
