Bath Tub Paint - Painting - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 03:56 PM   #1
Bath Tub paint
Hows it going? I am trying to find an easy yet effective method to paint my bath tub. It appears that I can replace my tub, and wall pieces on my own for about $400... but like everyone, I am a cheapskate and I like to save as much money as possible. This is not my "forever" bathtub. I just need it to last 2-3 years. I have seen many guides, but I am looking for someone who has done this with success. what paint/products should I be looking for? approx cost?
Thanks!
Spencer
skearton is offline   Reply With Quote
Old 05-27-2010, 06:22 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Good luck! This in not a home owner project, best left to the professional bath tub refinishers (IMO)
Old 05-27-2010, 06:25 PM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Thanks!
Spencer
There are products and it depends what your tubs made out of, mid west chemicals has a good line of refinishing products, but you need a sprayer to spray on and a special heat lamp to instantly cure the finish
housepaintingny is offline   Reply With Quote
Old 05-28-2010, 03:46 AM   #4
chrisn's Avatar
Rewards Points: 120
As I said, not a typical DIY project
Do most home owners own a sprayer or special heat lamp??
Old 05-28-2010, 08:14 AM   #5
Military Mom of 4
Snav's Avatar
I bought a tub refinishing kit from Lowes for $40.00. It came with gloves, two cans of spray-on tub refinish, tcp powder (cleaner) and steel wool. The paint is white, my tub is white and other than a few rust holes it's in decent condition. So, the paint worked great to give an even coat. However, the paint is dull - and my tub is glossy - so there are some spots which I missed and you can tell.
After prepping the tub with several rounds of tcp/steel wool/water rinse you are ready to apply the paint. The second coat needs to be done soon after the first - if you can't do it right away you have to wait several days for the initial coat to cure. . . so I'll hit the spots I missed later on.
For some touchup, yeah, works great.
However, I'd suggest to get a can of paint that you roll on instead of spray on - the spray is messy and it doesn't really seem to give a 'perk' over a roll-on version. I kept having to shine a light on the tub to see where I sprayed and where I didn't - it was hard to tell.
In the future I intend to replace my tub - so I didn't overlap the rim with surrounding durrock. Instead I fitted my durrock snug to the tub as a casing on the outside so I can then decoratively cover the rim and in the future just remove this lower tile and slide it out, replace without much headache.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 05-28-2010, 08:09 PM   #6
Rewards Points: 616
Professional re finishers spend thousands on special equipment, uv lights and hvlp sprayers and lowes sells a refinishing kit for $40???
Old 05-28-2010, 10:02 PM   #7
Military Mom of 4
Snav's Avatar
It is absolutely NOT professional grade. Maybe not even worth 40 bucks - it's uneven and it was finicky to apply to say the least.
But if you absolutely *need* to conceal scratches or, as is my case, rust spots - it's worth it
I'll get a new tub in the future - this is just temporary.
Old 05-29-2010, 01:13 PM   #8
How I Painted My Tub
Top Secret Coatings has a line of finishes you can find on the internet.
After one year, my refinished cast iron tub painting is still in good condition. Worth the trouble. It shows no wear (family of four)
STEP by STEP:
-Remove hardware, and drain trim
-dig out, and re-caulk with a good urethane caulking (no silicone please)
-Sand, and bondo any chip out, til fairly smooth
-rinse, and scrub with TSP/bleach, rinse well
-tape off, mask walls, and floor
-spray TS 664 etching primer
-lightly sand with 180/200grit till smooth
-check any caulked areas, and re-caulk as necessary til nice, and smooth
-spray TS2 Hard Shell 2-part Urethane (off white color)
-spray 2nd coat
You need 1 quart each of these two products for your tub
A cheap sprayer should work fine, and is the way to go; alternatively you can use a 2-2 1/2" china bristle brush if you remember to use the recommended reducer which will thin the product to brushing viscosity.
This 2 part urethane is quite durable.
jlintott is offline   Reply With Quote
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 04:52 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Painting over flat paint in bathroom lewisj Painting 2 03-17-2009 05:12 PM
