Bath Tub Paint - Painting - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 07:33 AM   #1
Bath tub paint
I was wondering if anyone has ever used the fiberglass bathtub paint. I have a tub that is in good shape, but powder blue. I dont want to have to cut the door and then reframe just to get a new tub in. Has anyone ever used this product before?
bc0604@yahoo.com is offline   Reply With Quote
Old 01-10-2009, 01:33 PM   #2
Drywall contractor
Rewards Points: 1,070
If it's a fiberglass tub/shower, take a sawzall to it and remove. You can replace it with a tub and 3 piece surround that WILL go through the door. I couldn't advise as to the paint, but it just doesn't seem like something that would be a good idea for a long term fix.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-10-2009, 02:44 PM   #3
Remodeling Contractor
Bath tub paints work fine. IF correctly applied. A lot of work. Box stores sell kits that are worthless. Just leave the product there and leave the money on their counter if you want to consider something like this. Epoxies also will not work. The tub needs to be chemically cleaned, etched and sprayed. If you have commercial spray equipment you are all set, if not hire someone to do this.
Old 01-11-2009, 11:33 AM   #4
Rewards Points: 506
You can hire professional bathtub refinishers. They will do a much better job than you probably could, with much less chance of a disaster. If it were my bathroom, and replacing the tub was out of the question, I would not risk a DIY.
SirWired
sirwired is offline   Reply With Quote
Old 01-11-2009, 12:01 PM   #5
if the DIY has experience with HVLP sprayer, they can do this just fine. The pro will do it better, but even a poor finish can be fixed with 1500 grit paper and rubbing compound. I do this professionally and know exactly what is required. Better done by a pro if you are not a good finisher with a spray gun. And in no case do it with a box store spray can, brush or roller.
Old 01-11-2009, 03:22 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
I have never seen a bathtub paint that lasted longer than 3 months to nearly a year, and all have left a worse mess when they fail
DIY Tub and Tile epoxies (quality ones...and following the direction exactly) seem to fair better, but the HD (big box) kits seem to be quite horrid
I have seen professional refinishes that were excellent, and lasted years
I've not seen a DIY T&T epoxy over fiberglass
Ask at your local Paint Store
slickshift is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
