Basement Window Frame Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 12-23-2011, 10:30 AM   #1
Rewards Points: 131
basement window frame paint?
Hello, i'm new here.
have a quick question regarding painting of basement window frame.
once i frame a basement window with 2x4 during building a wall in basement. do i paint the concrete & 2x4 thats framing the window or do i actually attach a drywall to the frame? if paint, is there particular paint use on concrete?
s002wjh is offline   Reply With Quote
Old 12-23-2011, 11:21 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Sounds like you are just rough framing- not a finished wall.
Is it rough cement or cinder block- or smooth?
There are block fillers, cement paints specifically for each.
Is the cement just in the window well, and you are rocking up to that?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-23-2011, 03:57 PM   #3
Rewards Points: 131
yea, its rough framing. not sure whats come after that? do i need some filler for the concrete frame or something else to make look like smooth regular window frame? i'm new at this
Old 12-23-2011, 04:36 PM   #4
Rewards Points: 12,818
I would not use sheetrock againt concrete. I'd do jamb extentions out of real 3/4 X what ever width you need wood instead. Your going to have to install the sheetrock first then build what's going to look like the walls of a box and just slide it in place, with the depth the distance from the winodw frame to the face of the sheetrock. Once that's done and finish nailed in place you can picture frame the casing around the winodow opening.
I would prime and paint everything before installing it on all sides.
s002wjh (12-24-2011)
Old 12-23-2011, 08:35 PM   #5
Rewards Points: 131
so basically something similar to this?
Old 12-23-2011, 09:02 PM   #6
Sort of. If I ever saw someone that worked for me making that silly template thing I would fire him on the spot.
Old 12-24-2011, 12:12 PM   #7
Rewards Points: 131
ok thanks,
Old 12-25-2011, 11:31 AM   #8
MikeKy55's Avatar
Rewards Points: 254
This is how I did mine. Used 1X6 poplar inside and regular trim on the inside trim.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
The Following User Says Thank You to MikeKy55 For This Useful Post:
s002wjh (12-25-2011)
Old 12-25-2011, 02:06 PM   #9
Looks nice
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
New window in old frame KurtP Building & Construction 0 09-12-2010 11:10 AM
Basement Window installation topher0524 Building & Construction 6 10-04-2009 05:46 PM
