Basement Paint - Painting - DIY Chatroom Home Improvement Forum
Old 09-23-2013, 01:15 AM   #1
Rewards Points: 39
Basement paint
I removed the old wood paneling in the basement, and now I'm painting the now bare block walls with Zinsser Watertite. I don't have a water problem, just thought it would be a good idea and help keep the humidity down.
However, some parts of the wall have been painted before, and not with the right paint since it's flaking off in places. How should I paint over these areas? I know that a finish is only as strong as what it's sticking to- if the bottom layer of paint flakes off it will take the top layer with it... So what kind of product should I use here?
Thanks in advance for your suggestions.
pick1e is offline   Reply With Quote
Old 09-23-2013, 04:03 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
After removal of all loose paint and cleaning
http://www.sherwin-williams.com/home...asonry-primer/
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (09-23-2013)
Old 09-23-2013, 09:05 PM   #3
Rewards Points: 39
I'll look into that. What are your thoughts on simply continuing over it with the Watertite I already have?
Old 09-23-2013, 09:22 PM   #4
Gymschu's Avatar
Rewards Points: 476
Usually products like water tight or UGL are ineffective if the wall has already been painted. Those products seal the tiny holes in concrete block and are effective at blocking out small infiltrations of H2O. If there is paint on the wall, the product in ineffective because there is already a coating on the walls. Unless you remove all the paint down to bare block, it is pointless to apply the waterproofing paint. I would simply recoat with a Satin Latex paint that you like.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
A Home Depot/Behr paint experience jeffnc Painting 31 05-25-2013 12:14 PM
Concrete in basement laundry/furnace room looks horrible - paint???? simiesue Flooring 4 11-15-2011 11:46 AM
