Old 03-26-2008, 11:38 AM   #1
Sftail2's Avatar
Basement cement floor
I am wondering how to clean paint, drywall texture off a basement floor that the guys left there after they finished there work hanging and painting the walls? It is all over about 1500 sq feet needs cleaned before carpet and tile can be laid down?
Sftail2 is offline   Reply With Quote
Old 03-26-2008, 08:13 PM   #2
ICF Construction
Mop and mop bucket, floor scraper, warm water and elbow grease
Chris
Chris Johnson is offline   Reply With Quote
Old 03-26-2008, 08:24 PM   #3
If that's you in the picture, I can come over and clean it for you.
jerryh3 is offline   Reply With Quote
Old 03-26-2008, 08:47 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Scrape off what you can
Mop up the rest
slickshift is offline   Reply With Quote
Old 03-28-2008, 08:40 AM   #5
Paint Contractor
There are scrapers that can be attached to poles so you do not bneed to bend down. If the lumps are not so pronounced I would not worry about it because the padding will be over top and you will not notice it. I bet there is less work than it looks like!
movado is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 06:06 PM
