Old 03-30-2006, 02:41 PM   #1
Question
Basement Ceiling
I would like to save some costs and give our basement a unique look. Has anyone painted an exposed residential basement ceiling? If so, what were your do's and dont's? I like the industrial look and would allow us to take advantage of our 9 ft. ceilings.
Thanks, Rookie.
PntrRookie is offline   Reply With Quote
Old 03-31-2006, 05:57 PM   #2
Painting Contractor
Basement Ceiling
I have painted exposed ceiling in basement with Flat Black (sprayed)... I recommend spraying....
Also, cover (mask off) all the important items.. such as... lights, smoke detectors, switches, outlets, panel boxes, water tank, furnace, and anything that seems important to you...
What ever color you chose... use FLAT... expect to apply up to three coats (first coat primer)using the sprayer and also... use the sprayer in different directions so you will cover all areas...
I recommend using an exterior Acrylic Solid Stain... dont need primer with it and it covers well and gives a very nice durable finish... It should cover in two coats...which will save $$$$
Joe
JMGP is offline   Reply With Quote
Old 04-01-2006, 01:34 PM   #3
Basement Ceiling
Thanks Joe,
So, correct me if I am wrong...use FLAT, and you recommend an exterior Acrylic Solid Stain (Flat). This will allow for NO primer and only two coats?
Did you paint (spray) all the duct work as well?
If I use black (which I like) and my ceilings are at least 9 ft high, will that take away from the brightness of the basement? I have four exterior windows on two partially exposed basement walls.
Thanks again, Greg.
Old 04-02-2006, 01:53 PM   #4
Basement Ceiling
Black will make your ceilings look way lower than what they are,
but that's a preference. Use a respirator mask when you spray.
Especially exterior products inside. The fungiside additives
in exterior paints and stains can be very overwhelming inside.
George Z is offline   Reply With Quote
Old 04-04-2006, 06:38 PM   #5
Painting Contractor
Basement Ceiling
Originally Posted by PntrRookie
Thanks Joe,
Thanks again, Greg.
Yes, If you are going to use an INTERIOR product use flat....
The Solid Stain... dries flat anyways...
Now that you mentioned "Duct work" I suggest using an EXTERIOR FLAT PAINT... it has better bonding capabilities for the duct work than the solid stain...
Make sure you wipe and clean the duct work prior to prime and paint...
You can just wipe it down with thinner if you want...
I would do 1/coat tinted Grey primer.... and 2/coats finish... sprayed...
Like George said... black will make your space seem smaller... and it will be darker... even with 4 windows... and use a respirator...
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 10:12 PM
Necessary to insulate basement ceiling between joists? yummy mummy Building & Construction 12 02-07-2009 12:19 AM
basement ceiling joists-how to know if they are level? yummy mummy Building & Construction 22 02-06-2007 09:16 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
basement ceiling options? courtney6 Remodeling 1 12-07-2005 05:07 PM
