Baseboards, Molding...corners And Nails.. - Painting - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 01:05 PM   #1
Rewards Points: 149
Baseboards, molding...corners and nails..
Hello to all,
Just thought I would ask a quick question or 2 now that we are installing our baseboards downstairs...
1. What is the preferred method of filling brad nail holes? Caulk? Painters putty?
2. Outside corders on baseboards.. same question... I have small gaps where the 2 45* angles meet, does anyone use drywall mud to fill this area in and then sand prime paint? Or is there another trick to the trade?
Thanks,
N
beachfront71 is offline   Reply With Quote
Old 04-24-2011, 01:37 PM   #2
Too Short? Cut it Again!
Wood putty if to be stained and I usually try to get it in the color closest the stain.
I sometimes use drywall compound. Usually though, since I caulk between the baseboards, other trim and walls/ceilings I have a caulking gun going and just fill them with caulk if they are to be painted as I go along.
Prime over anything but wood filler on wood to be stained of course.
Old 04-24-2011, 01:38 PM   #3
ltd
Rewards Points: 536
i like to use a product called ready patch its a very dense spacek press in in with flexible putty knife then scrape clean let dry then,once over with fine sand paper prime and paint .for corners and gapes use a quality paintable caulk
ltd is offline   Reply With Quote
Old 04-24-2011, 01:42 PM   #4
Rewards Points: 149
Thanks,
I have been using caulk but on areas that are eye level you can see all the holes that were filled.. I am trying painters putty right not but have not painted over it yet .
The biggest / toughest is getting the outside corners nice so they look good and handle any traffic that may bump them ..
Old 04-24-2011, 03:27 PM   #5
I use a lightweight vinyl spackle on holes, it has the consistency of thick shave cream. Press it in with your finger, overfill the hole. When it's dry sand it smooth. Dries quick, sands easily, looks great when finished. As to outside corners, anything but caulk will usually crack, though it's worth a shot to try the lightweight.
Sdsester, what does your last sentence mean? "Prime over anything but wood filler on wood to be stained of course."
Old 04-05-2013, 05:50 PM   #6
Jsheridan...what exactly is the product called that you use? Where do you get it?
risco is offline   Reply With Quote
Old 04-05-2013, 06:22 PM   #7
Rewards Points: 512
i use miter bond or 2p-10 for my outside corners. you glue the pieces together first make the joint perfect then nail it on. you will need next to no putty or fill just paint. for the nail holes use poly fill or a glazing putty. i also caulk top of the base and inside corners then paint it all.
princelake is offline   Reply With Quote
Old 04-05-2013, 06:31 PM   #8
Rewards Points: 12,830
Inside corners should have been coped so there was no gaps.
Outside corners can be tapped with a hammer to round them over and sanded so there is no gap.
Painters puddy or Fast and Final works for me.
http://www.dap.com/product_details.aspx?product_id=61
oldhouseguy (04-05-2013)
Old 04-05-2013, 08:31 PM   #9
Rewards Points: 5,974
I use M&H spackle But I would suggest not putting it in with your finger. If you look at the end of you finger it is round so when you push the spackle in it makes it concave, so it is already a divot. If you apply it with a flexible putty knife it is flat on the trim. And on the outside corners a trick I learned many years ago. If the gap is not to big take a screwdriver with a round shaft, hold both end and run the round screwdriver shaft up and down the miter and kinda burnish the joint. The high side will kinda collapse and fill the gap and you will never see it.
Old 04-05-2013, 08:55 PM   #10
Rewards Points: 512
i agree cope the inside corners it makes alot nicer joint. it takes longer to do but its worth it in the end.
i'm sorry but rounding the outside corners is such a hacker trick. i'd only do it on the baseboard that you already installed and that you need a fix for. if you have to smush and round the corner something is wrong. one piece is to long or your angles are out.
Old 04-06-2013, 04:11 AM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
You calling old Joe a hacker???????
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (04-07-2013)
Old 04-06-2013, 04:14 AM   #12
chrisn's Avatar
Rewards Points: 124
get it most anywhere, Lowes or Home Depot, any real paint store
Old 04-06-2013, 08:48 PM   #13
No cris it was me. I guess it's better to fill a small gap with chaulk.
Deck nails popping! Replace with screws? sliver108 Carpentry 7 07-21-2010 11:33 PM
Nails protruding through studs in area to be wired Mi Feller Electrical 8 06-06-2010 10:49 AM
My baseboards aren't working preciouschristy Flooring 1 10-05-2009 08:15 PM
